Shop made mortise and tenon jig
Greg Muller
I looking for a shop made mortise and tenon jig and thought I saw one here in the last couple of weeks but can't find it. Does anyone have one or a link to one.
Re: Shop made mortise and tenon jig
Re: here's one
Greg Muller
Bruce,
The link is not working.
Fixed it.
Dan Donaldson
The dreaded double "http://" ;-)
If you don't notice, there is already an http in the link box and when you paste, you end up with two of them. Just delete the one that is there before you paste and it will work.
Re: Shop made mortise and tenon jig *LINK*
Bob Entwisle in NJ
Here's one from a week or two ago
http://www.woodcentral.com/cgi-bin/messages.pl/page/1/md/read/id/431278/sbj/for-those-of-us-too-cheap-to-get-a-fmt-from-leigh/
Thanks.  I usually catch those.  Missed this time.
Bruce, a MN Galoot
Jim Dillon
Greg,
If the jig made by JL is what you were thinking of, I can attest to the fact that it works really well. I built a version of it maybe 10 years ago from a plan in Bill Hylton's book "Router Magic" and have used it a lot, mostly though for mortises, although it works great for stopped grooves in doors. I've also have used it for cutting the shallow mortises for Brusso offset pivot hinges etc. It is quite a versatile jig. Although you could cut a tenon with it, I use a separate jig on my TS for tenons.
Jim
Hal
A few years ago, Bill Hylton presented a considerably improved version of the one in Router Magic in PopWood. I've made them both so can attest to the improvement in the later one. It also excels in mortising the ends of rails, so it's great if you use loose tenon joinery. Can't recall the issue, but could probably find it. As to bits, (your later post) an upcut is probably best. Good luck. Hal
bits
Bruce, a MN Galoot
A couple years ago I got a solid carbide, two-flute, up-cut spiral bit from one of Ellis' advertisers. It is the most amazing bit I've ever cut mortises with. Mortises are the only thing I cut with it, saving it for that purpose, even though I'm tempted to use it for a lot of applications. It also doesn't get used for composites or plywood.
But mortises? Cat's meow!! And you KNOW what those cats are meowing about.
Jim Dillon
Hal,
Thanks for the tip regarding a newer version. I will try to find it.
Jim
