Router Table "Sub Top"
AZ in Colorado Springs
Last Christmas I received a cabinetmaking router bit set -- rail & stile bits, and a panel raising bit.
Well, I needed a beefier router than my little Skil router and I got the Freud FT3000VCE w/ 3-1/4 hp during a great sale at Woodcraft. I have a Rockler router table (with the large opening in the router plate), and last Friday I fitted the Freud router to the router table insert. This is great -- I now have a powerful router and a much better height adjustment mechanism from above the table (instead of a bottle jack positioned below the router, which worked OK).
Well, I still have a problem: the panel raising bit is about 3/16" wider than the opening in the router table insert, even without any throat insert installed. With the router raised all the way up, I can safely install the bit on the collet (it won't be inserted only partially into the collet).
At the wood skills shop at the Air Force Academy, where I volunteer every weekend, we have a Rockler router table with the smaller opening, and a Freud router table, and the panel raising bit is too large for that router table as well. So, no joy just using a router table there.
So, I'm thinking I'll need a 1/4" or 1/2" (not certain yet how much additional height I need) sheet of melamine coated particle board, clamped at the back and secured toward the front with double sided tape. I'll cut a hole about 1/4" wider than the bit, and I can clamp the fence to the table in lieu of using the T-track and t-bolts. Slowest speed setting on the router, of course, and little incremental bites on multiple passes.
Am I missing any lifesaving details?
