Help Help - softening or dissolving rubber
Terry Alexander
Why do we get into projects for in-laws?
BIL had another "project" for me. Wants me to rebuild an air rifle. Ok....this pellet gun is old old old. It will pump up to a gazillion pounds of pressure. However, the seals (inside) need replacing. And....yep....there are companies out there that specialize in parts for these old pellet guns.
Step 1 is dis-assembly. BTW....did I mention that I used to do some amateur gun-smithing? However....not pellet guns.
Dis-assembly...no problem.
Inocuous statement in the rebuild kit: "Remove the old rubber gasket". This gasket kind of pressure fits into a metal surrounding. It has been in there so many years it is as hard as steel. I swear I could finish this rebuild in about 15 minutes if I can get out this rubber gasket. I have tried a utility knife (whew....close to needing stitches).
Having said/typed all of that. Do any of you chemistry majors (or whatever) know what I can soak the gasket part in to get it soft enough to remove? It is in a steel casing, so I not opposed to using something caustic.
As always......thanks in advance!
Terry Alexander in West Texas
. As another poster said, neoprene is often a substitute gasket material. In this case, ketones (acetone, methylethylketone), esters (ethylacetate), or chlorinated aromatics (o-dichlorobenzene) might work, but availability varies. N-vinylpyrrolidone (a lactam) is sometimes a good polymer solvent and is the principal ingredient in one brand of paint stripper. A related class of aprotic solvents include DMF (dimethyformamide), and DMSO (dimethylsulfoxide) which might soften the neoprene material. While I've used all these solvents in my previous life working with polymers, most of the mentioned solvents are not readily available to the general public.
