Complicating the stock preparation process.
Virgil Johnson
Back in the 70�s when when we planed our wood in the high school wood shop we checked the thickness with a tape measure and we did a pretty decent job of getting it the thickness we wanted. We did not care if our �� walnut was actually .765 we were kids.
Flash forward 30+ years and I now complicate that simple task by using my digital calipers for checking stock thickness and try to get as close to the desired thickness as possible. (I got canned from the machine shop and I got to use them calipers for something). To further un complicate this now complicated matter of life and death process I made this attachment for my new planer that uses a travel indicator to aid in measuring the last cut.
Most of the stock I plane is less than 1� thick which is within the range of the indicator. For thicker stock the lower rod can be moved upward to contact the indicator.
I can now log on to any woodworking forum holding my head high and discuss getting my stock exactly the thickness I want.
Progress.
Re: Complicating the stock preparation process.
FredD
What did you use to fasten the Dial indicator ,Virgil?
FredD
Virgil Johnson
The indicator has a dovetailed backing plate and a matching holder. The holder is screwed to the planer casting with (2) 10-32 screws.
Stephen Kirk
I use my dial indicator because I find it easier to read. I often aim for a 32nd or more over to have some room to sand off. Even though the dial indicator is a precise tool, I use it rather roughly. If I get into the ball park of a few ticks around my number I call it good. I know those tick marks are really small numbers.
Plus I figure a few hours after I plane it the wood will have changed by a 64th or more anyway!
