Drawer/cross grain connection question
I have made my night stands and was thinking about the drawer. The top is 17" wide and I want the drawer to hang directly under it. the thought was to glue or Kreg Screw the side pieces for the drawer to the top. This means they would move with the top. They would be about a foot apart, so they would move however much walnut moves with seasonal changes in moisture. I was thinking of full extension runners on the drawer. They have a 1/2" side clearance and are not very tolerant of side to side variations. So, It would be better to hang the drawer in such a way it is independent of the top, right?
Re: Drawer/cross grain connection question
FredD
Right , Barry , like a drawer box with the drawer in it .
FredD
Lee Schierer McKean, PA
Normally the grain on a night stand top runs across the width, in your case 17". The drawer supports will be 90 degrees to that grain. The seasonal movement of the top will not change the spacing of your vertical supports as wood doesn't change much along the grain. It will however change along its width, therefore you will need to attache your drawer support pieces to accommodate the movement front to rear in the drawer. This can be done by elongating the holes in the back ends of the drawer support pieces or by mounting them in sliding dovetails.
Lee
