Lee Valley recent product for rust removal *LINK*
Dave Paine
I just tried out the Autosol metal polish product and really like it.
I had left a glue-up on my table saw in December. Although the glue was set, I foolishly did not put this on sticks or some barrier. The assembly lay on the saw for several days. My goof.
When I removed the assembly the glue line had caused some rust stains. Not deep, but ugly. I used the Boe-shield rust remover product, and it removed must of the rust but left a larger stain in the area applied, so I replaced small "bad" stain with larger stain but not as deep.
I applied a small amount of Autosol wiped with cloth and within a few seconds the original and Boe-shield stains were gone. In addition this product does a good job at polishing the surface.
This is a good product to have on hand. Too easy for water to find its way onto cast iron or steel surfaces. If you just want to polish your surfaces back to better than original finish, this is the way to go.
http://www.leevalley.com/US/wood/page.aspx?p=67014&cat=51&ap=1
