Glue for shoe soles OT
Randy Johnson
I have several pairs of shoes, mostly sneakers, but some boots as well, that have gone into early retirement because the glued on soles have started to separate from the uppers.
The most recent victims are a pair that SHOULD have a lot more wear to them were it not for the separation problem.
Has anybody here had any success gluing soles back on? If so, what did you use? I was going to just go for broke and try ultra-gap filling CA glue but thought someone here might have a better solution.
How I miss the days when shoes were made in such a way that they were repaired instead of discarded.
Re: Glue for shoe soles OT
Carol Reed, Strawberry, AZ
Shoo Goo.
Comes in several iterations.
Sorry.
Shoe Goo.
Editing a post may be possible, but it is neither obvious nor intuitive.
BilWil
I have used Pliobond for my work boots, running shoes, my kids, grandkids and my wife's shoes. I am satisfied, so is my wife, my daughters and my grandchildren.
Gary Smyth
Barge Rubber Cement is what oldtime shoe repair guys use. But it is messy, has fumes, requires 24 hours to stablize, and in my hands is about a one month fix. $22 a quart but in tubes also. Sold at shoe repair places, tailor supply companies
Clean clean clean...
John in NM
Some good suggestions here, especially the rubber cement. I would say the biggest problem in re-gluing any worn item is that there's usually significant dirt from normal wear and use to interfere with a good bond. I would start by cleaning extensively with acetone or another solvent - maybe several iterations of different solvents, and then glue with a rubbery glue like pliobond (basically contact cement) or the professional rubber cement.
Leo Cuellar
Gorilla Glue works great...
Leo Cuellar
but you need to be able to clamp the shoe together. Tried it a few years ago on some work shoes, it is now my go to glue for this job.
Hey Leo....
does that big ring of foam around your shoe bother you? Does it wear off pretty quickly? (sorry, couldn't resist.)
I laminated some redwood arches years ago. I am still find hunks of foam.
Barge brand cement is what the pro's use.
Scott in Montana
Barge is the glue used by all high quality custom cowboy boot manufacturers as well as the White Boot Company who is famous for workboots and boots for smokejumpers.
Barge is a contact glue. Apply to both surfaces and let them dry to the touch. Then press the surfaces together. Should be ready to wear in an hour.
Good luck!
Scott in Montana
Barge brand cement is what my shoe guy uses
Bruce, a MN Galoot
Re: Barge brand cement is what the pro's use.
Bill Turpin in WNC mountains
Plus one for Barge Cement. Tandy leather is another source. My orthodist makes adjustments to my custom shoes while I wait, he uses Barge. I wear the shoes out the door, they are the only pair that I own @$1800. I have NEVER had a glue failure! My 350#+ would certainly cause failures if it wasn't any good.
Leo Cuellar
Additional stub protection.
Leo Cuellar
Barry, the key with Gorilla glue is restraint :D As with all applications of GG I find the foam peels off pretty easy. I have also used it on the fly while wearing the shoes, but you don't get as good an adhesion at the edges. The other nice thing is that it works if your shoe is wet, a constant hazard @ work. It only has marginal success at sealing nail punctures :\
FredD
I had a Carpenter that for years exclusively worked on stacking and Sheathing roofs , so he wore lightweight shoes that routinely separated from the soles .
I had him stand on the work bench and shot some hot glue into the gaps and he pressed his foot down for a few seconds and hopped and got another six months or so of wear out of the shoes.
Wearing them during the repair does the best job of clamping.
The other option is Barge cement which I used for years in Leatherwork , and it is expensive and hard to find in many areas.
FredD
Thanks everyone
Randy Johnson
It sounds like Barge cement is the way to go.
I still miss the days when hiking boots all came with welted soles though.
