Humm .... can you bond Melamine??
Ron in Eugene, OR
Hello all,
I want to build a small book case with glass doors, on the cheap. The exterior needs to be paintable so the doors will be poplar and I would like to do the sides in birch. The enterior, desired, will be all Melamine (back, shelves and sides.
Is it practical and can I bond 1/4" birch plywood to 3/4" Meamine on the vertical end panels? I 'm think of using perhaps contact cement. I do know that you can buy sheet goods with hardwood veneer on one side and Melamine on the other, but I don't want to go to that expense.
Any input will be greatly appreciated. Thanks in advance!
Re: Humm .... can you bond Melamine??
Bonding
I'd rough the outside surface with like 60 grit paper, then apply pre-glued birch veneer to the exterior using a clothes iron and block. Don't think you'll get much cheaper or easier than that.
Re: Bonding
Carol Reed, Strawberry, AZ
Why not buy one sided Melamine? It's available. Then you'd be gluing to particle board.
rooglue.com
Jesse Cloud
