O.T. Truck Battery Running Down
Stuart Johnson
I have a '98 Dodge PU that doesn't get driven all that much any more. The problem is if it sits for much more than a week if that long the battery goes dead. A half hour on the charger and it's ready to go and will start just fine until it sits again. The battery is new.
1. What is causing it to run down?
2. If it is a bad connection how can I trace it?
3. Other than the trouble would I cause problems if I just disconnect the ground on the battery when I'm done using it?
4. Any other suggestions?
Re: O.T. Truck Battery Running Down
McKinneyMike
McKinneyMike
Stuart,
Something is providing a resistive path back to ground somewhere in your electrical system. A bad connection is not the issue, unless you are not charging the battery once it is running. I would get the new battery checked, then have the charging system checked to make sure that your altenator is indeed charging properly. Locating shorts and/or resistive shorts can be tough.
Removing the ground connection should stop any discharging as there is nowhere for the current to flow, but as you said it is a hassle.
Clean the battery well around the terminals. If there's a buildup of oily dirt, you can get a current flow to ground that will drain it. I'd check that first.
You could have a weak battery. A lot of auto parts stores will test them for free (having learned that they sell batteries this way). I'd check that second.
Most likely, though, is some kind of current drain. Modern vehicles mostly all have some kind of current drain when the vehicle's off - theft alarm, clock, etc. This is usually VERY low amperage, and I don't think should run down a sound battery in a week. Testing for current drain requires an ammeter sensitive enough to detect the low-amperage current flowing when your truck's turned off - this is inserted between battery and positive cable to the battery and the reading compared to what should be flowing. You then have to trace the problem - pulling fuses one by one, tracing wires for worn insulation, etc.
A lot of vehicles from the 1990s on have various security codes for radio, theft alarm, etc. that will get lost when the battery's disconnected. Read your owner's manual, if there is still a manual in the glovebox, to see if that's an issue with your truck. If not, or if you determine you can live with the consequences of losing the security code each time (like having to re-enter it every time you re-connect the cables), then pulling the ground cable may make sense. Make sure you know how to to do it and have the tools to do it without battery damage.
Dave Paine
As others have replied, the cause of the drain can be very difficult to track down.
If you are not able to find the problem, another consideration is to apply a small constant charge to compensate via a solar panel. The inexpensive ones are a trickle charge, but this sounds like all you need.
Harbor Freight and other location sell these. Hook up into a lighter socket. May be less hassle than disconnecting the battery.
Or it could be simple
Dave Bair, Eaton Rapids, MI
I found a light I left on in the bed cap that I had wired directly into the fuse box (bypassing the automatic low voltage override). The light was not obvious in the day time and I never thought to check it at night. It continued until I happened to open the cap's tailgate door and saw shadows where there shouldn't have been any.
Howard Norman
As others have said if the battery is in good shape and alternator is charging the battery when the truck is running properly it means that you have a resistive path somewhere that is draining the battery. Finding it can be a problem. If the battery is OK I would probable just buy a cheap trickle charger to leave on the battery when the truck was parked. If you park the truck outside than I would consider one of the solar powered trickle charges because then you don't have to worry about extension cords outside in the weather.
Good luck!!
old battery or new? and interesting facts on batte
Bill Tindall
I have a good friend who is a chemist at a battery company and we have just been talking about how/why batteries die.
The most common cause of death is age which leads to the internal electrodes corroding. They can corrode so badly that they just fall away from the posts and loose connection, or as common, the corrosion penetrates the spacers between the electrodes in the cell and causes an internal short. The latter is consistent with what you are seeing. Letting a battery discharge is a death sentence for the kind of battery used in cars. Hence, storing a battery unused leads to premature death.
Batteries are designed for a nominal 3 year life. Heat and over discharging leads to premature death while moderate temperatures and keeping a battery fully charged leads to longer than 3 year life. The only practical difference between a 3 year battery and one warranted for longer is the insurance policy that comes with the higher price.
PS
Bill Tindall
There are internal chemical reactions that occur inside the battery that discharge it even if it is not hooked up to the car. On a new battery this rate will discharge the battery in a few weeks at modest temperatures, much faster at hot AZ summer temperatures. As a battery ages it looses capacity to accept a charge. So an old battery with its poor charge acceptance capacity may self discharge in days sitting without any internal or external short.
A dirty battery can short( at low current) externally across the posts.
Lee Schierer McKean, PA
Since you indicate it is a new battery, I suspect something is left on that shouldn't be. Check your cab lights, truck cap lights, under hood light and glove box light, cigarette lighter, CB radio, etc.
On my boat the radio has a lighted display that will drain the battery in about two weeks. A single light bulb can drain the battery in a day or two.
Lee
McKinneyMike
McKinneyMike
I did not think of a small lamp being on when it shouldn't be. Do you have a courtesy lamp under the hood of the truck that is "supposed" to come on when the hood is lifted? Maybe it is staying on.
Re: O.T. Truck Battery Running Down: Thanks
Stuart Johnson
Thanks for all the answers. A trickle charge is what I'm going to try. If that doesn't do the job I'll just disconnect the battery.
Re: O.T. try this
del schisler
try this take the neg leed off. Now make a tester with a 12 volt bulb and put it in serries with the ground. It shouldn't lite . If it does take the fuse's out 1 at a time tell the lite goes out. If the leak is so small that the lite doesn't lite up than get a volt meter and put in serries like the bulb. Now set the voltage down lower than 12 volt tell it read's something. Than do the same thing with the fuse's. That is the easest way to do this. I have been in electonic's repair for 50 yrs and this is the best. Or use a amp meter?? But a volt meter will do. Good luck Also when you start the car check the voltage on the battery it should varrie let the motor idle turn on light's now watch the meter rev up motor and see if the voltage varrie's ? Or take it to a place where they can check the alt. and surface charge on the battery . That would be easer for you
Bill Tindall
It would be useful to know if the battery has an internal short, in which case if it is "new" it can be replaced on warranty. I would disconnect the battery and see if it discharges, or not, with nothing connected to the terminals.
If indeed there is something connected or shorted in the truck you could over time pull fuses until you found the offending circuit(with luck) or at least eliminated places to look. An ammeter on the battery would be handy for the task.
Modern "maintenance free" batteries do not like to be overcharged. Modern cars have electronics to see that overcharging does not happen. A trickle charge is acceptable so long as it indeed is a trickle. In the old days too much charge would simple turn the water in the battery into oxygen and hydrogen and the only ill effects would be needing to replace the water. In the "sealed" batteries of today if they are overcharged and produce gas the battery will vent, loose water and there is no handy way to replace it.
3 years plus
Jerry Nicholson
That 3 years can be extended a lot if you get the battery out of the engine compartment. When I sold my 1981 FIAT Spider (battery in the trunk) the Delco battery was at least 10 years old and working great. My wife's Chrysler 300C is approaching 7 years old and still has it's original battery (in the trunk!). On the other hand, the battery in my Dodge Dakota (under the hood, of course) quit at about 4 years. With the battery in the trunk, I have seen very little corrosion buildup around the terminals.
Jerry
It is the heat, and other battery data
Bill Tindall
The way these data are presented is screwy but it is what I could find quickly. The graph plots % loss of battery power per year upon storage vs temperature. The loss axis is log scale, and for some screwy reason plotted upside down from normal graphs. Note that the lead acid battery (what's in the car) dies rapidly at high temperature. Under the hood is the hottest place in the car.
Other factors are leading to shorter battery life in modern cars. To save weight smaller batteries are installed. Yet with all the electronic stuff the battery is called upon to do way more than just start the car. (When buying a replacement buy the bigggest battery that will fit in the space, More lead = more life). Modern batteries have thinner spacers between the plates to get more "cold cranking power" (lower internal resistance)an irrelevant metric unless you drive in MN in the dead of winter. Thinner spacers are more vulnerable to shorting.
Go to the BORG
Dustmaker Mike
Yup the orange one has a Solar charger on close out for ~$14 here in OH. They may have them near you also. You plug it into the cig lighter adn put the panel in the sun and the battery stays charged.
Truck Battery
Jerry Nicholson
When I replaced the battery in my Dakota, I opted for the much more expensive Optima battery. Failed in two months! I went back to the dealer and they didn't want to believe me - they claimed they had never heard of an Optima failure and tried to prove I had installed it backward or something. After a little discussion they replaced it and I haven't had a bit more trouble in the 3 years or so that it has been in the truck. The construction of the Optima quite different from the construction of normal car batteries.
Jerry
Re: O.T. Truck Battery: Part Two
Stuart Johnson
I received my new trickle charger yesterday and set it up and for once something did just plug in. So much for the good news. When I went picked up the box to toss I noticed in some very small print "The adapter requires a socket that works with the key out of the vehicle ignition". Nothing on my '98 Dodge works without the key except some of the lights. I'm flat out of luck using the charger unless I rewire a socket into maybe the glove box light.
Would that small light fixture support a cigarette socket or am I down to driving around just to make sure the battery is charged. Do most vehicles have sockets that aren't ignition controlled? If not what use are the trickle chargers?
Bill Howatt
My Dodge mini-van has a cigarette lighter which is key controlled. It also has what is called an accessory socket for usually entertainment devices etc. The accessory socket is on all the time and the wire feeding it is smaller than the lighter socket wire. I think in a proper accessory socket you cannot plug in a cigarette lighter but you can put an accessory plug into a cigarette lighter receptacle.
Bill
97 chev astro van does
del schisler
just get a socket and run a couple wires thro the fire wall to the fuse box . Their is probly a open fuse with power on it ?? wire it their. The charger doesn't draw a lot of current? not 15 amp or 10 amp??
The lighter in my 99 Mazda PU is live all the time. I know because my sat radio and GPS will run the bttery down. OTOH my Honda CRV did nt have a live all the time power port, which I know becasue I needed one for the flashlights I use on my inpsections. I wired one out of the fuse box. Pretty easy. I wish one in the Mazda was not live all the time.
Barry
My guess is that it's not the battery, but I would have it checked out first just to make sure. Then, the alternator. That's the two easiest things to get checked. If neither of these is the problem, it gets a little harder from here. A circuit probably has a small leak to ground. But, using the charger is sort of like bailing water out of a sinking boat without noticing the hole in the bottom that's letting in all the water.
A while back, I had a problem.
Keith Newton----Little Rock, Arkansas
I was down at the cabin, got up before daybreak to go hunting. The battery was dead, so I tried using the charger in start mode, but that didn't work, so I took the battery out of my boat over to jump from it.
I took that battery along in the truck bed, and had to jump again after hunting a few more hours.
The day had warmed up enough while driving home, that I attempted to roll the windows down. Well, there is a little switch on the drivers arm-rest that child-proofs that door lock and window. It had gotten on by accident, so I flipped it back off. There must be a short in that system, because I have not had a problem since.
I wonder if you have a similar short in one of your lines. You could probably turn everything off, then pull each fuse, and check with a tester across to see if you are getting energy flowing through somewhere that it shouldn't be going.
Battery Buddy / Battery Brain
Larry Clinton Sr.
I had never owned one before, and have had my previous vehicles batteries run down just from setting a week or so in the winter (and leaving dome light on etc.). I bought a used GMC custom Van a year or so ago and it has a "Battery Buddy" under the hood. I noticed it when I purchased the van but didn't pay much attention. However last winter we had an extreme cold spell & I didn't move the van for a week or so. Went to start it and it didn't click, remembered the Battery buddy so raised the hood and sure enough it had "kicked out". I pushed the button and it reset - van started right up. I think this has happened about 3 times in the last 2 years. I really like it. Its easy to run my van battery low as I carry a portable refrigerator and have a GPS, Radar detector and other devices I occasionally use with the van motor off. I did a search and the "Battery Buddy" is no longer available. Now they are offering a "Battery Brain" with various options for prices ranging from around $60 to $105. I will probably install one in any future vehicle as it protects battery drain from leaking to ground, normal discharge from clocks, lights left on etc and silly things like leaving the refrig plugged in with the van off.
