"Ingenious" dovetail layout device
Bill Tindall
I am expecting someone will tell me they saw this in an 1740's tool chest. At least theirs wasn't made from Plexiglas.
It is made by making two angled saw cuts in an over sized piece of 1/8" Plexiglas(acrylic). The material between the cuts is the size of your favored dovetail for a drawer side. Then the Plexiglas is cut to come convenient size and mounted in a wood block.
Background: One should settle on a dovetail size for drawers based on what looks good to you and for which you have a convenient sized chisel. Once settled every dovetail from there after will be the same size in front of the drawers. A larger size and fewer of them is customary for the back of the drawer where there is little stress on the drawer. The ingenious device handles both these needs.
Step one is to scribe the base lines with a marking gauge.
Step 2 is to use the device to make the outside "half tales as show in the picture. Some feature on the device can be used to align it for consistent half tail size. In the picture I am aligning the outer edge of the saw kerf with the baseline.
Step 3 With a compass divide the space between the half tails into X equal parts , where X is the number of pins desired. While this division is trial and error, with just a bit of practice I can get it sufficient within 2 tries. Mark these spaces with a pin prick of the compass or a pencil mark as shown in the picture as the black dot under the acrylic.
Step 4 Center the tail of the marking device on the pencil mark and then use a pencil of pen to mark the tail.
Step 4 For the larger tails on the back of the drawer I mark using the outside of the kerf which results in a larger tail than marking on the inside of the kerf.
This handy device has saved a lot of aggravation marking the nearly 200 tails in the chest of drawers I am building.
