Hey Barry Irby
Moses Yoder
I am wondering if the carburetor on that snow blower you are trying to start has a float and needle or a diaphragm to put gas in the carb.
Hey Barry Irby
Moses Yoder
You talkin' to ME?
Moses, I am trying to start everything I own.
The first thing was a leaf shredder grinder that belongs to a friend of my son. It appears to be about a five HP engine and it on a Craftsman unit. I know nothing about it except that here is a screw in the bottom of what I would call the sediment bowl. I tried loosening the screw about half a turn and it did not help. I added SeaFoam to the gas and my son and I ran it briefly on starting fluid. We had already tried spritzing gas on the air cleaner and got it to run a few seconds until the fumes ran out. So we gave up. I really don't want to take somebody else's machine tot he shop and have it repaired, but OTOH that might be the right thing to do. After all, we are using it for free (if it would run).
Then we tried the tiller. I have one of those tiny Ryobi rototillers. I have had it for six or eight years, but I have never used it. My son has used it a few hours. Got it out and pushed the primer bulb and it crumbled. Then realized the gas lines are also crumbling. Went on line and found the parts and they are mailing them to me today. Then spent about and hour looking at YouTube videos on how to replace the parts. YouTube is astounding. Actually found a video of the very machine I have. So when the parts arrive I feel confident I can make the replacements.
How do I identify which carb I have?
Re: You talkin' to ME?
George Koch
Barry, just a thought. Are you using gas with ethanol added in it? George
I always buy high test for these things but I don't actually know if it has ethanol. I suspect someone put ethanol gas in them and I suspect that ruined the bulb and plastic gas lines. OTOH, surely there are materials that will stand up to ethanol, it has been around quite a while and shows no signs of going away.
Buy Low Grade Gas Re: You talkin' to ME?
del schisler
Re: Carburetors
Moses Yoder
A carburetor with a float and needle in it will have a round bowl type thing attached to the bottom for the gas to go into the carburetor. If it has a diaphragm the carb will be flat on the bottom or attached right on top of the tank with a gasket at the bottom of the carb. Your shredder engine is not getting gas through the carb if you can run it when you put gas in the air filter. It either has dirt or old gelled gas in one of the passageways the gas is supposed to go through in the carb. There are adjustments on the carb for the amount of gas it gets at low and high speed, 2 screws with pointy ends on them. For a carb with a float in it, I would remove the carb, take the 2 adj. screws out and remove the float and needle and any rubber or plastic parts that you can, soak it in parts cleaner overnight then blow it dry with an air hose and put it back together.
