200+ woodworking book reviews
finishing figured maple
Steve Kirincich
From my background reading, it is my understanding that the use of a dye (water or alcohol based), rather than a stain, will really make the figure of my curly maple boards look great. Would using a medium dark shellac have a similar effect? Thanks.
Steve
Re: finishing figured maple
Ever look at a violin (or similar back)?
I would say that the grain pops on a lot of those. They use shellac and/or varnish.
David Yoho
My favorite method of finishing curly maple begins with a water-based dye that's darker than what the final color will be. This application does two main things. Once dry it will show any sanding marks or glue residue left behind. The other thing is it is readily absorbed into the figure, which will highlight it later. I sand this first coat of dye with 150 or 180 paper, removing most or all of the dye on the surface along with scratches or glue residue. Sanding at this stage also cuts any fuzz from grain raising due to the water.
With the figure highlighted and the surface ready for finish, I use a water-based dye to give it the desired final color. You'll notice a profound difference in how the wood looks once you apply your finish of choice.
Applying most any top coating will cause the figure to look highlighted, since the figure absorbs it more than the rest of the surface. However, if you want to really make it pop, the dye method is the best choice, I believe.
Dave Paine
I have only tried this on two pieces, but I agree that dye works better than stain.
The stain is more viscous and does not penetrate as well as the dye. Perhaps the pigment particles are also smaller in the dye than the stain.
Try a comparison on a test piece.
I did my own comparison of dye then oil vs oil alone. I preferred the oil alone, but this was a personal preference for this particular piece. I have seen some stunning dyed pieces.
