dovetail practice
dovetail practice
dovetail practice
Jerry Gibbs
Whats the best wood for practicing hand cut dovetails?
Re: dovetail practice
Moses Yoder
Moses Yoder
Scrap wood.
Re: dovetail practice *LINK*
charlie belden
Mahogany - preferably Cuban Mahogany. There's a reason it's called The King of Woods. Easiest wood to cut, carve, saw, pare . . ..
Next best bets - maple, cherry, walnut.
Worst - new vs old growth pine because it crushes rather than is cut.
Poplar is relatively inexpensive and readily available - so try that, Doesn't crush as easily and works pretty well.
Regardless of the wood - SHARP will make all the difference in the world. And DO NOT try to chop out the waste with one or two chopping cuts.
Havving a procedure in front of you as you practice . I think there's one in the Articles section here on WC but if you can't find it - here's an illustrated set based on Frank Klausz's procedure
Hancut Dovetails Instructions
anything
Bill Tindall
How tight a fit can be tolerated in the assembly depends on the hardness of the wood species involved, so I usually make a few practice dovetails out of what ever I am using on the project before proceeding to the final product.
All of them
AZ in Colorado Springs
A soft wood is good and easy to start with, but harder woods will cut and chop differently. Changes in grain lines, hardness of the wood, etc., make each instance a bit different. Christopher Schwartz once suggested in an article to cut a set of dovetails a day for a month to get practice and develop some skills. I did about 18 sets in a month's time, and by using different species from the pile of cutoffs I saw how they differed.
