Clock Restoration-1/2 column spindles
George Colonel's Workshop-Havertown PA
Good Evening Friends,
My best friend Charlie volunteered me to wreck somebody else's antique clock. Actually, we will be partners in this effort, which needs an assured outcome. He is well equipped to replicate much of the missing mahogany filigree and molding. The clock had two pairs of half column spindles, one pair on either side of the face. One pair is missing. The missing pair sat close enough togethe to require perfect conformity, one to the other.
I told Charlie we should attach two half blanks through release paper, and turn the spindle on a lathe, then seperate the two identical half columns.
I think that is probably the simlest approach, But what paper to use? And what glue at what strength. I have no practcal knowledge or experience. Help
George
Re: Clock Restoration-1/2 column spindles
Don Evans
I've used one sheet of newspaper and regular yellow glue.
Also a brown paper bag (grocery) will work, perhaps it will give little more strength.
Anything that the glue can soak completely through and bond the other side.
But be careful with the spur and tailstock. Best to use a two spur (not 4) with the blades 90 degrees to the split in wood, on the tail stock take out the center pin and use just the ring or cup.
Don
+1 on what Don said.
I've used brown kraft paper or the thinnest grocery bag paper and yellow glue. I use my Sorby Steb Centre as opposed to anything else.
The thicker newspaper works - if the newspaper in your area uses it.
Re: Check this place  *LINK*
del schisler
I have delt with this place for probly 50 yrs or so. They may have just what you want. good luck
http://www.merritts.com/clock_parts/public/default
Re: for easy/no clean-up of the glue
Sue McLam
George,
Make your turning stock longer than what you need and then just put glue on what will be the waste area, clamp the pieces together until dry and then go turn. Cut the waste off when you're done turning and your parts will separate and there will be no clean up needed. I did this on some bedbosts (I needed 3/4 rounds) and it worked like a charm.
Sue
