Delta bandsaw disappointment
Joe Pack
I posted a message a week or so ago asking for comparisons of Delta 28-206 and Grizzly 0555P 14" bandsaws. Today I had a chance to stop in at Hartville Hardware, Hartville, OH, to take a look at the Delta I was considering. After checking the Delta first-hand, I will go with the Grizzly if I do pull the trigger. I eliminated the Delta for these sometimes disappointing reasons, and please tell me if I'm wrong:
1. Delta is $540, Grizzly is $500 delivered (and rumor has it that there is a 10% coupon in the next Woodworkers Journal issue)
2. Grizzly includes a decent fence/scale, Delta sells it for a $140 add-on.
3. Both have 4" dust fittings, but the lower door of the Delta where the dust fitting is located does not close completely. Even when tightly closed, there is still a gap of at least 1/2" all along the bottom, plus an indent of sorts at the very bottom of the case where, even if the door did close all the way, there would still be an opening of about 1/2" x 6". Hardly a set-up to hold in or direct dust. The Grizzly I looked at last summer was completely enclosed.
4. The actual castings on the Delta were rougher and more coarse than anything I have seen at Harbor Freight! The cast iron finish, particularly under the table and on the dust collection outlet, would never have been passed out of a Beginning Metal Casting 101 class. Honest to goodness, it actually had ridges, projections and humps that would shred your hand if you tried to pick it up at that point. I could actually see the "grain"of the casting. To see such material and finish on a Delta absolutely shocked me. (To be fair, the casting on the more expensive model was not so rough, but even that one was not up to the standard of the cheapest Jet sitting near it.)
5. The 6" riser kit for the Delta was $140, the Grizzly riser kit sells for about $70. I may or may not use one, but, if I do, $70 is $70.
6. The Grizzly offers a quick release tensioner, the Delta I saw does not. (To be fair, the descriptions and pictures I have seen on several web sites say and show a quick-release lever. Maybe the lever was missing on the one I looked at; I didn't think to ask, and I only had a few minutes to play since I was on my employers's dime..my "lunch," if you will."
7. The Delta does have an enclosed stand that I prefer, but I can add a bit of weight to the open stand on the Grizzly if I need to.
I have found a couple of used Deltas somewhat near me, but the asking prices are almost as much as a new saw, higher is some cases.
For what it's worth... Thanks for reading.
Let me know and we could plan it for any Saturday coming up.
