dovetail drawer labor saving
Bill Tindall
Hand cut dovetails are stronger than some machine cut assemblies and the design freedom leads them to typically look better. If people didn't fret so about making them "flauntable grade" and others insist on judging the workmanship of a piece by micron imperfections in the dovetail joinery I would venture to say that more would use this attractive joint. Another issue is that they are slow to make, even if you don't strive for flauntable standards.
I was shown a way to cut some labor out of making this joint and I have adapted it enthusiastically. The technique involves fastening two drawer sides together and cutting them as one unit, halving layout and sawing time.
Rough cut the drawers sides and nail them together at diagonal corners with two small nails. (One of these nails can be seen shining in the picture.) Joint the bottom edge so the two edges are even. Rip to width and trim to length. Layout and saw the tails. Band saw out as much of the waste as you feel comfortable doing. I like to get within 1/64-1/32 of the base line. Chisel to the base line on each end and each side. Separate the boards, scribe the base line on the inside face and finish chiseling to the base line on the inside face.
I also have a quick way to layout the dovetails which I will post later. There are nearly 200 dovetails in this bow front I am making and making routine operations (I call it apprentice work) less tedious was attractive. What you see in the picture is the LAST! drawer, of 9 total.
