We value your privacy.
I managed to get the blade back into alignment, thanks for all the advise yesterday. I have another question regarding the wiring of the on/off switch. Since my saw is on a mobile base with drawers etc, I unbolted it and leaned it forward to get to the trunion bolts and I guess when I removed the motor, it pulled the black and white wires off on one side only.
Looking at the back of the switch the blk/wht wires on the left are off (GRN stayed on) wires on the right are still attached
? O O GRN
? O O BLK
GRN O O WHT
Load Line
I can't remember how I had it when I installed the safety paddle switch. Thanks for the help. Rick
I don't quite grasp the layout you were trying to convey.
If you've got a volt-ohmmeter (also known as multitester), check which terminal on the load side (the side going toward the motor) relates to which incoming wire, and match the colors - white to white, black to black. If you don't have a multitester, the terminals opposite each other on the sides of the switch are probably what gets turned off/on as you operate the switch.
Bill, thanks, I don't have a meter, so if I understand your answer, looking at my diagram, I attach the balck across for the black, white, across from the white ? Rick
Thanks Bruce, I tried that before writing to the forum, the person I spoke with didn't have a clue as this is a safety paddle switch that replaced the original switch supplied with the saw back in 89.
I multimeter is one of the better investments in a woodshop, especially if you plan on wiring this yourself. If it's an aftermarket switch you might need one to figure out where the wires go. An electrician could fix it to, probably for a $90 service charge. A multimeter runs prolly around $20 for a cheap one and then a couple hours to figure it out. If you are not handy around electricity, call the professional.
Thanks Moses - I will pick one up for future needs. Didn't realize this was a tough question, maybe I didn't explain it very well. I have all but 2 wires on the switch, there is one black, and one white loose. Do I attach the black wire across from the other black, and the same for white? I think that is all I need to understand to get the saw running this afternoon. Appreciate the responses.
If I'm reading you correctly, there were four wires attached to the switch. To me it would indicated that your saw is wired for 220V. I would also tend to think that 2 blacks should be on one side of the switch, and the two white wires should be on the other side of the switch, as in the hot wires black and white should be at the top two oposite side lugs, the wires black and white going to the motor should be at the bottom two oposite side lugs. I'm no electrician, so don't go by what I say, wait for others to respond and either confirm what I said, or discredit me.
On the Delta Contractor's saw that I own there is a quick disconnect about 6 inches out from the motor. You may want to consider doing that to yours also so the next time that you want to remove the motor you don't have to go through what your going through now.
Rick, I'm sure you have realized by now that this is a great use for a digital camera. Take a picture before you disassemble something. I wish I had paid attention to this notion before I started working on my car recently.
I would bet if you have a switch wired with a whale and black on one side, the other black and white wires go across form them. This would make sense compared to a switch I installed on my Performax.
Of course I am willing to make this bet because its your saw, not mine. Also pretty sure that if you hook it up and its wrong it will trim the breaker and not really harm anything. That's bad advice. You really should get eh meter and check it out. You could also check it out with a light bulb in a socket with wires hanging out. Just go from ground to the line black and the bulb should light. Then go from ground to load black. Switch on, bulb lights, switch off, bulb does not light. Then with the switch off go from line black to load white and bulb does not light. Switch "on" bulb does light. You could wire short leads to the plug on any light and use that. If you do this be careful and tape up the connections to keep from getting shocked. I usually have enough junk parts laying around to make a home made continuity tester.
Barry, you are right, a camera, or at least a diagram (which I now have both) would have prevented a lot of grief. Good news is the problem is solved, the answer was black on the load to black on the lead,- white/load, white/lead, checked with a meter. Runs fine, no smoke and the alignment works as well. Guess this will hold for a while. Thanks again for the help. from everyone.
If you know that they both are either coming in together, or going out together, it should not matter in a 4 pole switch for AC current. But if the black is on the top of one side, then I would do the same on the other.
I think you have a Double pole single throw switch. DPST. If true, that might indicate you could covert the motor to 240 fairly easily and would not have to rewire the switch. At the moment you have a switched neutral.
Rick, I guess that even if it's setup for 110V, I would think that blacks on one side of the switch, then whites on the other side. Another way to confirm it would be like on an outlet, black to the gold colored screws, and whites to the silver colored screws. As I stated before though, I'm not an electrician, but I did stay at a Holiday Inn once. Can you get us a picture of the switch and whats going on ?
