Machinery mover
Machinery mover
Machinery mover
Jim Runchey
I remember seeing a plan for a gadget for moving shop tools, a lever that raised the front of the platform for moving the power tool. Anyone have a picture of this?
Re: Machinery mover
Re: Machinery mover
Don Evans
Don't remember that but sounds like you are looking for what is referred too as a "johnson bar".
Go to google and do search on that without the quotes.
One of these came with my bandsaw a minimax MM16. The rear wheels are bolted to the machine and the johnson bar made for it hooks into a hole in the foot pedal that operates the brake to stop the machine.
Don
Re: Machinery mover
Re: Lever Dollie or Mule
james runchey
I was actually looking for a plan to make one. Thanks
Re: Machinery mover
ronald rimmer
Years ago Norm made something with one of these, it was a handle with 2 small wheels on the end with a hook that fit into an eye on the dolly. when you pushed down on the handle it would lift that side of the dolly.
Ronnie
Re: Machinery mover
Re: Machinery mover
Ron in Sterling, CT
WOOD magazine had plans for one several years ago. I am sure that it probably can be found at their website. Good luck.
Ron
Re: Machinery mover
Phil Joines
I made one a while back. Piece of 2x4 about 6' long. Tapered down to 1 1/2" on the handle end with a cross piece of 3/4 dowel to make it easier to pull. The other end has a piece of 1 1/2" angle with the upright at the end of the bar. Held on with 5/6" carriage bolts. The wheels are 5 or 6" dia. Like you'd have on a mower. They are mounted to the lever on a piece of 1/2 threaded rod and nylock nuts. The axle goes thru a hole in a 2x4 block that's bolted to the lever about 6" from the end. Most of the locations can be eyeballed depending on your wheels. It works ok in a strait line but it's a PITA to turn.
Re: Machinery mover
Re: Machinery mover
TomD
That's a new one to me, thanks for bringing that up. I have some 1/4 plate and I think I will just weld a piece across the end of another, with an inch of overhang to rest on the end of the lever. That should make the hook strong enough.
I used a dollie at a machinist's house that consisted of about a 1.125" bar of cold rolled, onto the end of which he had turned a stub that fit a large bearing. Then there was some screw arrangement to hold the wheel on. Very rugged and made moving extremely heavy machines effortless. That would work well with this lever dolly.
