REAL MILK PAINT
Small Table Saw Gloat *LINK*
Chuck Lenz
I bought the 8" PowrKraft ( Montgomery Wards ) Table Saw from a guy locally and did a full restore on it. Not sure what I'm going to do with it, but I thought that it was too cute and rare to pass up. At the bottom of this post is a link to the restore in the VintageMachinery website.
VintageMachinery
Re: Small Table Saw Gloat *LINK*
Dale Lenz
Dale Lenz
You did a Very nice job on cleaning that baby up!
Enjoy
Bob Entwisle in NJ
Nice e Job, Chuck!
pete labelle
My shop is in the basement of our house. For quite a few years, I had a small tablesaw like similar to yours that was run with a 1/2hp motor. Built a large base with enclosed bottom, wheels on one end and carry handles on the business end. Put a good 50' cord on it, and included an outlet at the saw. Worked well for an outside "beater" saw for general cutting needs outside. Built my porch, deck, and storage barn. Precision stuff still happened from the basement, but saved a ton of trips up and down the stairs.
Pete
Brad Chenoweth
Great job on the restoration, Chuck. My father bought a similar saw in the fifties (when he was working at Wards), and built many projects with it over the years, including a full custom kitchen. The fence on it is a solid steel bar, but otherwise it looks almost identical to yours. My son still has it in use in his basement shop, with the original 1/2 HP motor. It sits on a wood stand, along with a 4" Atlas jointer from the same era, also still in use. Those pics have me thinking about doing a little restoration on it, too. Thanks for posting it.
Brad Chenoweth, finally above freezing in NE Ohio
Chuck Lenz
Pete, after puting all that work and time into it, I don't think that it will end up being a beater saw for me. I have two shops, my main shop is in our double stall garage, then I have a small shop aproximately 10' X 10' in the basement that I putz around in the winter. In the basement shop I have an old AMT 8" table saw that I installed a 8" sanding disc that I bought from Sears a few years ago. I may do the same with this saw, or use it in the basement shop for makeing small projects like birdhouses, etc. in the winter. I think that it's a perfect fit for that shop because it takes up very little space.
Bart Goldberg
Impressive Restore Job!
Bart Goldberg
Gary Smyth
During the restore how difficult was it to realign the saw blade and the slot?
Very nice job, Chuck.
Bruce, a MN Galoot
I have a friend who has one just like it, but yours is in MUCH better condition. Good work!
Chuck Lenz
Gary, it was fairly easy to line the blade up being that the top was upside down. I just lined it up with the outer edge of the cast top. That should be pretty darn close, if it isn't, I guess I'll be tweeking it again.
Re: I forgot to mention
Chuck Lenz
That there are four pins that are pressed into the cast top under the throat plate. I removed those and tapped them out for 1/4" set screws, now I can level out the throat plate. Also the bolts that fasten the Trunions to the top have large Phillips screw heads on them and two of the bolts are hard to get to with a screw driver, so if I have to realign the blade I'm going to switch those bolts out to a standard bolt head that I can get a open end or box end wrench onto, that would make the job of aligning the blade easier. The fence is cast iron with an Aluminum strip across the top.
