Help! Bit stuck in drill.
Scott in Montana
Hello all,
I have one of the small 12 volt or more correctly 10.8 volt Bosch drills. I was doing a bit of light duty drilling Friday and left the 3/8" bit in the chuck. Today I went out to clean up the shop and I can't get the bit out of the chuck. The keyless chuck just won't turn.
Any tricks or suggestions?
Thanks,
Scott in Montana
and put them around the two portions of the chuck and tighten them both snugly. This should apply even pressure to the grip without damaging it. You can also increase your leverage with a pair of Channellocks against the screw on the clamp.
