We value your privacy.
I uploaded some photos of the workbench I'm building.
I still have some work to do on it, but I had a big step yesterday by taking it off the saw horses. Kind of like launching a ship and then you have a lot of finish work to do.
I took these in my garage with two SB-600 flashes. There's glare in a few photos that I'm not going to take the time to remove.
Here's one small pic to get you started, please have a look at the gallery, a lot of you had input on this bench and I'd like to show you how it is coming. Also how many of you have seen a workbench with a sound system?
That's a good question. I knew that I was going to winch it down on its side and then prop it up. I didn't want to have the wheels in the way when I did this. Not so much because I was afraid of them rolling around, but I thought there was a chance they'd break.
a bench with multiple drawers as yours will accumulate tools (see pic) that over time will make the bench difficult to move. I suggest at least 4" medium duty, solid rubber industrial casters, swivel, with a plate, not a post, even though they may raise the bench higher than planned. Plan on a 300 lb caster on each leg. My last move had my bench at just under 800 lbs what with the drawers filled and the vises. Anticipate future weight and try to find wheels that won't be prone to flat spots. They will be relatively expensive ($10-$20 each) but over the life of the bench you will be pleased that you bit the bullet now! Once on the bench chances are you will never touch them again.
Last November I built the jack.bench.com. It does do all the woodworking I need, and it is adjustable from 29" up to 41" by using car screw jacks. Also, can lower a jack underneath and move the bench aroun d.
Their website: jack-bench.com // view the videos and see what Charlie made.
I really appreciate the information. I estimate that my bench weighs 600 pounds empty. When you say get 300 pound casters per leg that means they could support 1,200 pounds, right?
I'm in the Seattle area, does anyone have a suggestion on where to find commercial casters?
Thanks for the comment. There's a reason for the Bose sound system, I wanted to mount the speakers into my 2 x 4 stretchers (actual 2" x 4", I milled all the wood from 5/4) and I spent a lot of time looking for speakers that would fit without removing almost all the wood. I admit that I smiled a little when all I could find were the Bose.
The PVC conduit also has a purpose behind it. It's so I don't end up slicing any of the cords if a tool sticks up where a wire hangs down. The other reason is that if I need to run another cable/cord I have pull cords in place to just yank the new cord through. (And pull a replacement pull cord through at the same time.)
I do appreciate the "cool" comment, made me smile.
I admit that the speakers are a bit much, but I like to listen to music when I'm woodworking, and I thought that this was a good solution.
I wouldn't pay extra for casters with a brake. the weight of the bench will hold everything still. If it does want to move on a project use a wood wedge or even a rope against the wheel and the bench will not budge.
Thanks, I was wondering about brakes, that makes sense.
On the Google thing - if you Google caster Seattle you get about 354,000 hits, 353,990 are completely worthless, which is why I ask if anyone has a recommendation.
Caster, heavy duty, 4" swivel. You will get sites -- some from Grizzly and Northern, Reid, Woodcraft too. Make a choice and call for help from vendor if necessary. What you want depends on your floor too. I'd get a solid wheel and not have to be concerned about throwing a tire.
OK, so in fairness, I'm a photographer, and photographers collect interesting images for future use. Whenever I see interesting clouds, or a nice sunset I'll shoot it so I can drop the clouds into a scene when the sky is pure blue, but the image calls for something to take up some space. I'll borrow colors from a sunset to put some punch into an image, you get the idea.
So when I saw my hand like that the first thing I thought was that it looked interesting, and if I ever wanted an image like that in a photograph it would be very difficult for me to reproduse. So I grabbed the image while I had it under good lighting conditions. I have no idea if I'll ever need it, in fact the type of work I currently do has never called for a bloody fist.
But... if I ever have an image that just aches for a bloody fist, or hand, or some element of it, I GOT IT!
BTW - here's a link to a sample of what I usually do, this and sports. I didn't add anything to this shot of Mt. Rainier, everything was in place to get the shot, I did enhance some colors, and massage some of the elements to make it flow better.
I got four 4" casters rated at 325 pounds. Solid rubber coated with a slightly softer rubber. They'll add 5 1/4" to the bench, so I'm going to cut off the feet, which are 4". The casters cost $12.25 each from Industrial Caster and Wheel in Tukwilla (on Andover Park E for the locals).
Thanks to everyone for your help.
Anyone need two pieces of 4" x 4" x 36" European Beech?
