drill press
laurie power
the chuck on my drill press has a habit of dropping off at the worst possible times . i've forced it on as hard as i can but can't find a permanent solution . any suggestions?
drill press
laurie power
Paint the quill with rubber cement or oil poly
Clint Searl
Let it dry and whack it tight. Either it'll hold or not; if not, try something else.
Clint
Re: drill press
FredD
A coat of Shellac will do it , paint it and press it home and your done.
FredD
Re: Paint the quill with rubber cement or oil poly
Doug Ring
Is this a tapered mount, used either with or without a Woodruff key? In my other hobby life (kart racer), our clutch's drive hub mounts this way (tapered fit to crank, held on with a large fine-threaded nut) and it is very important to get a good surface purchase between the hub and the crank. To do this, you need to use valve compound (available at the auto parts store) and lap the tapered joint surfaces. First lap using the course compound (will knock down any high spots), clean well with brake cleaner, then repeat using the fine comound (will smooth both surfaces). a Well-lapped hub will hold together like it's welded, with minimal nut pressure; an un-lapped hub will almost always come loose, even with the nut tightened to 100+ ft/lbs.
If you are near a kart shop, stop by and ask them about lapping a clutch for installation.
Back in my mo'cycling days,
one street repair for bolts that vibrated loose was clear nail polish (why clear over colors, I don't know - it may have had more to do with the sensibilities of the mechanic than with the usefulness of the product). Apply, slap it in place, let dry.
I believe nail polish is a form of lacquer, with more body than finishing lacquers - so this makes sense.
Clean, Clean, Clean!!!
George, Oxford, NC
Use mineral spirits and clean the spindle taper really good and then clean out the female part really clean. There is something to be said about lapping the two so all surfaces (interior and exterior) are smooth WITH NO BURRS. Place the taper in the drill press and press down on a block of wood really hard. Do not 'BANG' the head down on the wood but use a good strong steady pressure. Do this with chuck all the way open so you don't damage the three fingers inside. Using any additive on the taper will most certainly lead to problems down the road IMHO.
George
Re: drill press
My previous chuck (original to the press) fell off occasionally. I finally polished the shaft/taper on the DP with a diamond hone. I have the set of three little plate hones and used the finest one. I just ran the DP and gently pressed the plate on the taper. Cleaned the shaft and chuck well. Reseated the chuck with a little lock tight. Later when I wanted to remove the chuck to replace it with an upgrade it was a real struggle to get it off.
If you don't have a diamond hone use some really fine sandpaper (400, 600, 1000 or higher, you get the picture) and a piece of smooth wood or steel as a backer.
Agree on all points....
John in NM
The problem is that the manufacturer skipped all that time consuming cleaning, fitting, and lapping that George explains. Properly done you can hardly pull a tapered shaft without a slide hammer or something similar.
If you do want to try the quick route, I'd favor a thinner and harder adhesive like shellac. If you only use the drill press for twist drills under 1/2" in wood, this would probably suffice. The vibration from hole saws, big forstners, fly cutters, etc. will quickly cause the quill to drop again.
hard to find now,
but crocus cloth is the traditional abrasive for this kind of polishing.
If you can't locate it, e-mail me your mailing address and I can send you a strip from the stash I got from my uncle.
Cleanliness is next to holeness!!
Phil Joines
Re: hard to find now,
laurie power
thks Bill and the many others who offered suggestions . i'll try them all and report back .
Re: drill press
Bob Entwisle in NJ
When I've run into this problem on a couple DP's in the past, I've found that a good cleaning of both the socket and tapered shaft does the trick.
Remove any signs of rust and then a good wipe down / flushing with something like brake clean or other solvent to remove ALL signs of oil or grease. Then swing the table out of the way and insert the chuck into the socket make sure the jaws of the chuck are retracted into the chuck, and with a hardwood block on the chuck one good solid rap with a 2lb hammer will seat it firmly. I'd hesitate to resort to any sort of adhesive solution unless all else failed.
Let us know how you make out.
Bob in NJ
this procedure has always worked for me
Bill Tindall
Re: drill press
steve mackay
in my bad ol' motor biking days i partialy stripped the nut on the rear axle. called dad (tool & die maker) and he said loc-tite (red). tried it and it held so long i forgot about it 'till i broke it down for re-build. it was STILL a bear to get off. when i bought my drill press the priorf owner had replaced the chuck with a 3/4 and i had your present problem. asked dad if the same fix might work. well, gee steve, thats what its made for. been four years now and still solid as a rock. god bless RTV and loc-tite.
Re: drill press, what Bob E. said
Chuck Lenz
Agree, agree
Lee Schierer McKean, PA
You can also polish the tapers inside and out with sctochbrite. Feel the taper for any signs of burrs and insure the inside taper is clean on the bottom so the arbor taper can go all the way in.
Lee
