"Fraternity proof" finish for coffee table?
A friend has offered his compressor and the use of a 2-part conversion varnish. "Two coats, that's all it will take...". Obviously lacquer is out. I don't know about Deft Clear Wood Finish. Polyurethane or spar varnish is a choice - I don't know how good of one.
Other thoughts, preferences? I have Sherwin Williams, Benjamin Moore, Home Depot and Lowes within 25 miles. Woodcraft and Rockler are down the mountaint ~90 miles away. The Benjamin Moore dealer will order anything I want - if it is carried by his distributor (he's getting me some Deft Clear Wood Finish).
Re: "Fraternity proof" finish for coffee table?
Jesper, Denmark
Jesper, Denmark
Spar varnish is too soft. A floor finish intended for high traffic areas may do it.
.............or to be completely safe, how about laminating a nice piece of stainlees steel to the top? :D
John McGaw
Hmmmm... Fraternity proof... How about 1/2" stainless steel?
Nat Robison
While there may be no such thing as "fraternity-proof" or for that matter, "12-21 year old male proof", Rockler sells something called Rockhard. I've never used it but its portrayed as a bulletproof finish.
that is what I use
Bill Tindall
This will be a finish that can be washed and it is reasonable abrasion resistant. I use this finish for any sort of table that will get "used". I find it useful enough that I buy it by the 5 gallons from Sherwin Williams.
Many years ago...
I made a bar for the Frat house. We had a left over bench top from one of the labs. I often wondered what happened to that bar.
Re: that is what I use
Jesse Cloud
I like Rockhard,too. Not quite as good as 1/2 stainless, but it has held up well in several stressful applications for me.
Only thing to be aware of is that Rockhard is very slow curing. Give it a good 2 weeks to finish hardening before letting the frat at it. If desired, once it has hardened, it polishes up to a nice shiny finish.
Hardest Finish *LINK*
I've yet used is General's Enduro WB Poly-Clear with cross-linker additive. Have had it on a coffee table in the play room for several years and there's not a mark on it. I applied it with a top-cup HVLP but dialed back the air a bit and stayed at least 12" for the surface. What I wanted and got was a very uniform, but very fine orange peel texture that acts like diamond plate to take any wear on the top of the tiny bumps while preserving most all of the film and finish. Here's a pic of the off-the-gun finish.
There is a waterborne lacquer that I've had recommended to me under the name of "Unaxol" as the closest thing to an industrial wear coating that can be applied and cured conventionally. Last I priced it, it was stupidly expensive at something like $50/quart. Here's the link in case you want to go further.
UNAXOL
Steve Schoene
The conversion varnish would be pretty tough, a notch tougher than the Rockhard, BUT, unless there are some spray facilities suitable to deal with the toxic potentially explosive solvents used, I'd leave that to professionals. It would also be well neigh impossible to repair if damaged.
I'd go with the Behlen Rockhard. It's good stuff. It's label says not to thin--don't believe that, it's pretty syrupy stuff without some thinner. I would use the Rockhard Reducer sold by Behlen. The Rockhard works better with the stronger solvent in the proprietary solvent. The cheap stuff works fine for cleaning brushes though.
What's the wood?
A film finish can't be any harder than the wood it's on top of. I hope this coffee table is made from a good dent-resistant wood.
From what I saw working at a university, I agree that steel (or granite or concrete) is about the only "frat-proof" material.
Clint Searl
Re: Hardest Finish
Clint Searl
I have a quart of Unaxol that I got from the guy when he first started importing it at least 5 years ago. It's a waterborne, formulated for spray. I've never tried it; just too wedded to solvent lacquer, I guess.
Clint
Cherry
