OT- central vacuum systems
We'll be gutting our lath-and-plaster walls some time this year (probably) to insulate the house and put up sheetrock.
My sweetie has a bad hip and back, and just today, we discussed the possibility of a central vacuum system (I brought it up, not her - this is not technically a honey do). It seems, in theory, like something that should make her daily life easier.
Our house is just 1600 square feet, and most of the central systems seem oriented to larger houses; but this might make a lot of sense for her, if it's less physical strain.
I'd like to hear any experiences or thoughts from folks. While we have the walls open is the ideal time to do this, if we're going to.
Re: OT- central vacuum systems
Bill Howatt
It can be lighter than a regular vacuum but it depends on what your regular vacuum is. Also, if you have a very long hose it requires more effort to get it out and drag it around. This can be alleviated by more wall inlets. I don't really know what lengths are available.
My wife, who also has her share of aches and pains, says she does like the central vac but in reality she more often pulls out a light weight Dirt Devil and uses it. Our central vac has a powered beater bar.
Our house is single level no bigger than yours. The other advantage of the central vac is that you can vent it outside to eliminate any dust that would blow through a bag.
Would be good if you have a friend or neighbour with one she could try.
Bill
Re: central vacuum systems - never again
Galen Vetterick
Had a Beam central vac system in a home with about 3800 sq ft on two levels.
I thought it was more work than it was worth. NO problem with suction or cleaning but you drag a long heavy hose around and scuff corners and furniture. The power head made just as much noise as a good upright. The canister was wall mounted in the garage and I finally piped the exhaust outside as even a muffler did not help cut noise when in the garage.
Over time the outlets need replacing as the door seal gets bad or the power contacts wear from use.
Where I am now is three floor levels to clean. I have three good uprights with automatic power drive. Never have to carry one up or down stairs. With power drive it is just an effortless push or pull on the handle to run it around. You usually have a lot more electrical outlets to chose from than outlets for central vac.
Just my opinion but I'd forget the central vac and get a good automatic powered upright.
Bill Howatt
The electrical outlet is another issue. Ours requires you plug in the beater bar so it is necessary to have an electrical outlet near the vacuum outlet.
They are noisy but I don't really find it too bad even if the cannister is near my workshop door. I close the door to my shop and tolerate it, after all if I complain I'll get the vacuuming job!
Bill
Don Evans
Have had two, one in previous house and one in present house. We downsized, getting old I guess. Anyway, previous house was 4000 sq ft and we had one of the best (my opinion) systems on market. It was a VacUMaid and was cyclone, no bags or filter of any kind, just empty the canister about every 6 months. It had dual motors and was powerful.
As far as "dragging hose around etc", that just depends on how you design the system as you can go two ways, one is longer hose to carry with less outlets to plug into, the other is more outlets with shorter hose.
The house now has a Beam (not cyclone) and I regret going with it wish I had done the cyclone but the Beam is better than no central IMO.
The absolute best thing about central is all the dirt goes out of the house, I don't care how great a push around unit is, it can NEVER stop all the air born stuff it stirs up and blows back into the room.
No matter what brand you go with, I would recomment no more than 12 ft hose and put in enough outlets to cover area with that max length. If the unit is located in the garage get another set of tools and hose just for using in the garage for cars etc. The static cling on the tools and hose will make that set dirty and u don't want them in the house.
Also u don't have to do a remodel job to install one of these, the folks that do it put them in existing homes all the time. Both of our homes were built prior to installation. They make it look easy but I wouldn't want to do it.
Don
while the walls are open
Stuart Johnson
You've probably already thought about this. While the walls are open it would be a good time to upgrade the electric and run all the new type media and internet wiring.
I have had one and installed one for my father. I am in the camp of those who were not that impressed. The hose is about as much trouble as the unit. The noise was not much better. Just not what I thought it would be. No noticeable difference in the dirt being stirred up and returned to the house. I suppose that technically the dirt is exhausted out doors, but I never noticed the difference.
A question about venting outside.
Keith Newton----Little Rock, Arkansas
If you are venting to the outside, besides exhausting your heated air outside, don't you need to be letting some air back in to keep an efficient flow?
I guess that would give a good reason for waiting until Spring for a good Spring cleaning.
Thanks, yes
I rewired the house about 15 years ago (from a scary mixture of knob-and-tube, BX, old-style cloth-covered "romex", and just plain frightening indescribable stuff done by a homeowner who knew little or nothing about electrons). Hours of crawling around and fishing wires into stud bays; used up a good ten years worth of cuss words.
About all we'll do with the electricity is fasten the boxes properly to the framing.
But, yes, I plan to install several boxes for media wiring. Although the future of media seems to be wireless, it's worth being prepared for whatever isn't. My plan is to do boxes with conduit stubbing into the crawlspace.
Lee Grindinger
Consider this *LINK*
Lee Grindinger
Bill, we bought a Roomba robotic vacuum several months ago and really like it. It's small, can be programmed to work daily at specific times and does a really good job, especially since it works everyday. It won't do stairs or furniture but it goes places regular vacuums can't. I don't know the layout of of your house but it will do multiple rooms as well as carpet and hard surfaces.
iRobot.com
Re: A question about venting outside.
Yes, if you vent out side air WILL find its way back in. These were older houses that were not that tight, so it found plenty of ways back in. OTOH, if your house is tight, it is possible for the air to come back down the chimney, sucking whatever fumes back with it. Remote chance, but conceivably dangerous.
When I run the DC in my shop, the cat's door opens. Have not sucked up the cat, yet.
We have no hose storage problems *LINK*
Scott in Montana
We installed a cyclone style vacuum canister in the attached garage which is about thirty feet from our garbage dumpster so emptying it every few months is no problem at all. Being in the garage, it is almost silent in the house. The home's air exchange system easily makes up for lost air.
At the same time we installed one of the hide-a-hose system where the hose is actually stored in the vacuum piping. You pull out however much hose you need, up to fifty feet, attach the upright tube and power head, and vacuum. When you're done you put the power head in the closet and let the vacuum pull the hose back into the wall.
We put our hose outlets at 24" so it wasn't so much of a bend to reach it. The one we like the best is under the kitchen sink, we use it all the time to vacuum the hard floors.
Attached is a youtube link to one of the retractable hose company's video.
Love it!
Scott in Montana
hide-a-hose link
Jennifer Indy.USA
Bill,
If your wife is having back and hip issues perhaps instead of installing a new vacuum system, that ultimately still requires pushing a vacuum and lugging hose, you might take over doing that chore and relieve some her discomfort that way? It sure would be cheaper and you wouldn't have spent a dime.
Just a woman's point of view I guess?
Jen
We've had two! *LINK*
Lee Schierer McKean, PA
I have put two systems in our current house. The first was a Hoover and it made ton of noise. It lasted about 15 years. When we replaced it I ran across the Thin Vacuum site where they compared nearly all major brands of vacuums. They even provide recommendations based on house size. We ended up going with a Drain Vac Pro and couldn't be happier. It is quiet enough to be in the basement at the same time and has excellent suction. It also came with a free muffler and hepa filter. We were able to use the same hose connections and beater bar from our original unit. Most beater bars will require an outlet within 4 feet of the hose connection.
Use a length of rope to determine where to put out inlets and then try to minimize the number of elbows in your vacuum line runs as much as possible. It is a pretty installation, even with the walls totally finished.
Lee
Think Vacuums
