ISO suggestions for protecting plywood from water
ILYA Z
I'd like to build a semi-enclosure of sorts in the back of my yard against a chain-link fence. The idea is to build two opaque walls that will be attached to the fence. For this I want to use some scrap plywood that I've collected. The question is how to protect it from the elements so that the plywood does not disintegrate after one humid summer. I can paint the sides but what about the ends? I was thinking of using the type of caulk that is used to patch up cracks in concrete. But will it hold on to the wood or just fall off? Anything better than the caulk?
Thanks!
Re: ISO suggestions for protecting plywood from water
Phil Joines
If it were me I'd buy some pressure treated ply.
and even with pressure-treated ply,
the lumberyard I use - which caters to contractors, so they're not dumb - recommends treating the cut edges with copper or zinc napthenate.
Using untreated ply may be a very temporary solution - but perhaps that's all you need. And, having been young and broke once (instead of middle-aged and not quite broke), I can sympathize with using found materials.
I'd consider this: if the ply is 1/2", get J-edging for sheetrock at your local lumberyard/big boxy store, and put it on the top edges of the plywood. If it's thicker, look at the available flashing for something you can bend over the tops. Hold it on with galvanized 3d nails, driven through and clinched.
But first, get fence paint and paint all edges and faces of the plywood; then apply the top edging and paint this, slopping over onto the existing paint.
When you're installing it, hold it up off the ground a few inches - setting it right on the ground will accelerate rotting.
You might get a few years out of this - two, maybe three, maybe even a bit more - depends on your tolerance for imperfection.
John E in SC
As Bill suggested, I'd try some kind of flashing for the edges rather than caulk - with the expansion and contraction of the wood, I doubt caulk would stick very long. You will certainly want to avoid ground contact as well.
Just as an example, I built my son a treehouse a couple years ago using untreated T-111 plywood siding (rated for exterior use), and other than a tin roof which covers the top edges, it's had no other treatment. It has held up quite well going on 3 years now.
FredD
Yes , the better finish and one I used on several sets of steps for kids competition swimming , was a Rubber based paint applied with a hand held Wagner airless cup gun.
The sides of the steps were exterior rated plywood with a exterior face and exterior glue and the treads were solid wood.
I last saw them arter three years of use and while they were partially immersed in water , there was no failure in the plywood or paint.
If your material has a stamp saying so or a red painted end , then it is exterior rated.
Painting the edges as well as the fronts and backs will be all of the sealing needed, since the paint will be in the wood as well as on it , which caulking can't do.
FredD
You have a number of different issues.
there are many different grades of plywood and stuff like plywood such as OSB and particle board. As for as I know none of the particle board is rated for wet exposure and if it gets wet it falls apart quickly. Don't use it. OSB (oriented strand board) MAY have some rated for exterior use. Try to be sure before you use it. Plywood may be rated for interior or exterior use. The exterior stuff gives you the best chance of holding up in the weather. You should treat the edges and paint them. Treating them with copper naphthenate helps resist decay but does little to prevent them delaminating from being wet. Sealing the edges with excellent paint is the best chance you have there.
None of these products are rated for soil contact. Try to keep them 6" off the ground.
The pressure treated plywood will hold up in the weather but locally they treat the sheathing grade material and it is not attractive. It is generally not rated for soil contact but usually holds up better than the untreated stuff.
Howard Acheson
Let me make the point that you want to start out with a plywood or composition panel material that is intended for exterior use. Much plywood and composition material is intended for interior, protected locations. The adhesives used are not water resistant.
