We value your privacy.
So I guess I need a Hygrometer. I have 2 right now a digital and a dial type guage in a fixture with a thermometer and barometer. The digital is registering 13 % lower than the dial type. Not sure of the quality of the digital.
So any suggestions? Is there a good accurate one?
I just had a whole house humidifier installed 2 days ago and am running it on the furnace WITHOUT Heat just the blower on a low speed.
There are a lot of units that are both good and accurate. They also happen to be pretty expensive. I use an Oregon Scientific unit (BAR208HGA) which measures temperature and humidity indoors and outdoors, includes an atomic clock, etc and is probably accurate enough for most folks. It will support up to three remote sensor units although it only comes with one. If you could use a long-term record and demand superb accuracy then there are units which are often seen in museum settings which log readings every minute or more often and download their data to a computer to show detailed records over long periods. The sky is the limit for items like this.
And unless you're slicing silicon wafers to make computer chips, it is more of a pain to use than it's worth. For the same money a digital time-temp-humidity unit is just as accurate, and doesn't need to be twirled.
In this context, this is a useless piece of trivia, but for measuring RH the sling psychrometer is the method of record. I do Expert Witness Testimony on construction defects and it turns out the courts have some methods that are established as the way to do things and to get an acceptable reading you have to use a sling psychrometer. Otherwise you have to demonstrate your unit was calibrated against one. And yes, they are a PITA, especially in a crawlspace.
I would think for an indoor application the accuracy isn't terribly critical. Your sinuses and skin will tell you what you need to know. Kind of like the remote I saw on a heat pump that did not list any temps. It had two buttons, one said "I am too hot" and the other said, "I am too cold". You will learn that when your gadget says the RH is between X & Y you are comfortable.
Your unit must be wired different than mine. The solenoid that turns on the water supply is only activated when the thermostate is set to heat and calling to run . If you manually turn the blower on it does not activate the solenoind as it is a bypass to control. System is not wired to run by blower control as it would run in air conditioning cycle too.
Just wondering if your humidifier is really running on fan mode only.
So be careful. Among Home Inspectors humidifiers are often thought of as mold factories. Mold is the ban of the industry and some of the manufacturers are in denial. Watch your unit carefully and clean it well.
Also, some of them put out enough water to rust ductwork or furnace cheat exchangers. Be careful there as well.
Barry , sometime ago you expressed interest in acquiring a Humidifier and asked me what the make and model I used was.
Like any appliance that is adjustable , you need to pay a modicum of attention to the settings until you have it just right and by all means use a Bacteriostat solution with each filling.
