We value your privacy.
I've been trying to figure out how to hang a drawer under a top. Thinking of using some sort of slides and want it to be very minimalist. A small drawer, perhaps twelve inches wide and two inches deep and sixteen inches long. Any thoughts?
Several manufacturers make "under mount" slides. I've purchased them from Lee Valley (one of our advertisers), but I'm sure they are available from Woodcraft, Rockler (additional advertisers) and probably others.
The angle iron wasn't there, and the part under the top supporting the angle, was lower, and rode in a slot in the side of the drawer box.
Keep it waxed, and small drawers work pretty good.
I have even done them where there was a two sided dovetail key in the middle, which slid in a dovetail slot in both the drawer box, and carcass part, with a slot on opposite side / opposite ends, which allowed full extension.
It is hard to describe, but you need a screw / pin to keep it from sliding out of the ends of the slot on both sides.
I take it this is still part of the night-stand design problem. Hang in there Barry, I think I am sensing progress now. Ha
I glue a strip of ipe or other incompressible hardwood to the top edges of the drawer sides using trim-head screws as a mechanical backup for the glue. Then I plow a mating slot in the runners and attach them to the underside of the top.
Would that be any better, or as easy as if you just cut a groove in the side of the drawer, leaving that same height and width to ride in the matching groove in the hanger slide. You could still use the screws to prevent some of the splitting force of thinning the side.
>Yes and no. If the drawer sides are thin, you couldn't have a very deep groove (say, a max. 3/16" deep groove in a 3/8" side), and there wouldn't be room for a reinforcing screw. Of course, there probably wouldn't be much danger of splitting unless the groove were too close to the top edge of the drawer (by definition, brilliant, eh?). With either system, you would have the most risk of splitting when the drawer was approaching full extension.
It might be considered an advantage, aesthetically, not to have that flange sticking out from the top edge of the drawer, but there's some justification for it. That way, I can use a gnarly, hard-to-break wood like ipe for the slide strip and screw/glue it to a softer, weaker wood side, say of yellow cedar or poplar.
Been there, done that. It works fine for a small drawer. I wuld just have a rabbet in the runners and leve some slop - easier than the groove. Chamfer the runners a little at the front, and lubricate with some wax.
I've used rabbeted pieces of Brazilian Cherry to support drawers on a cherry Shaker sewing table. It works fine. I was able to mill them down to ~5/8" or so.
This approach probably isn't wht your looking for , but I like drawers totally enclosed and on this Computer Stand I made form Cherry Plywood and solids, I first made a box that the drawer fits in and runs on side mounts and then attached the box to the bottom of the top and and off set it to the side so I could open it when seated in front of the keyboard.
