BreadBoard End Protocol
Alan Young
I am building a farmhouse styled table. The top will be 72" long and 36" with breadboard ends. My material is 5/4 clear cut pine-each board is 9"" wide.
My layout plan is for a bread board cap with hidden tenons. The tenon and matching mortise is 1/2" thick. The cap is 4" wide with the tenon 1.75" long. The outside boards will have the tenon haunched in 1.5"- the matching mortise on the cap is in 1' allowing a 1/2' on each end for movement.
My understanding is that normal pinning/gluing would have one dowel fully pinned and glued in the center and two outer dowels-pinned but not glued-in elongated holes. I'd like to have two dowels close to the center-glued and pinned-spaced 2" apart...
Is this sequence going to work?
-Alan
Someone parking themselves on it at a party is about the only case I can think of where what you have pictured would likely break. If you don't throw parties or have kids, nothing to worry about
