Age Degrades Sandpaper?
I have read that age degrades sandpaper. But I have some that must be ten years old or more and it seems fine. I think the comment was mostly about belts for belt sanders and that the glue joint that holds them together will fail with age.
My concern is for strips for a Performax/drum sander. I would like to buy some in bulk, but if I do they should last me for years. Does the glue holding the grit on fail with age? In bulk they cost about half what they do in small quantities, but if I end up throwing half of them away it would not make it much of a bargain.
Re: Age Degrades Sandpaper?
steve mackay
since i've had an "out building" shop it seems it is more a matter of humidity / moisture. when it rains and then humid even my 3X gets a little "soft". belts that are kept dry and dark in the house keep better. of course neither belts nor sheets hang around more than a couple months.
Re: Age Degrades  the Sandpaperee also
And the sandpaperer as well
Neal in San Jose
Lee Schierer McKean, PA
I buy 100 disk packs of PSA type for my ROS and some last several years. I've not noted any degradation in adhesive performance for the PSA or for the abrasive. My shop stays fairly well closed up and is heated/cooled by the house HVAC.
Lee
