How to color match?
How to color match?
How to color match?
Henry (Raleigh, NC)
I have a straight forward project that requires me to do some color matching - make the new parts the same color and finish as the old parts.
In this case I could take the piece to the paint/stain place to be scanned, so I may actually do that.
Of course it is not hard to imagine situations in which it was not possible to scan an existing piece directly. How would you go about trying to color match an existing finished piece?
Thanks
Henry W
Re: How to color match?
Ray - Middletown, IN
Practice, patience, scrap wood, and a color wheel. If it is something I haven't done before with nothing to reference, I cut up a piece of the wood I am going to work with, maybe 3-4 inch pieces. Then I put on the my best guess of dyes or stains, whatever, and compare to the piece I am trying to match. I write on the back of the piece for future reference and then start adjusting on the next piece/s using the color wheel to help move the color in the direction needed. I write on the back of all of the pieces what I did for future reference as my memory isn't worth a hoot anymore (as if it ever was).
Ray
Color match? Dyes? pigments?
Henry (Raleigh, NC)
Thanks Ray.
Do you have a full array of TransTint dyes or something? Water or alcohol based solutions? Dry powders?
Or are you mixing the various premixed MinWax (or other brand) colors of oil based stains to get to your desired color?
Henry
Re: Color match? Dyes? pigments?
I have a fairly good supply of Transtint dyes, Mixol, and various other potions. I mix with water or alcohol as desired and sometimes tint the finish for toning and shading. I also mix Minwax stains as needed. Everyone knows I play in the shop so they are always bringing unused stains and such. I have some dating back 30 years or more that I was going to toss but have found they come in handy sometimes.
Ray
Jesse Cloud
I put a small piece of clear glass on top of the original piece and then put a trial dye mix on the glass. Easy to compare colors.
But, this and the scanner are imperfect. The color will change some when you apply it to your new wood.
If you are doing this for pay, show a sample to the customer and get him to sign the back of the sample, indicating that he will pay for the work with this color. Do not play "bring me a rock" with the customer or you will go broke for sure.
