Veritas - Innovation in Tools
Cutting "Man Made Granite /Marble
Mark
Has anyone ever cut this stuff? It is a man made material that is used to fabricate one piece vanity tops with the built in lavatory. I am told from the plumbing supply that you use regular wood cutting power tools to cut it.
I am buying a 2'x 4' slab for a laundry room counter top
This stuff looks and feel like solid stone but is some kind of "pour" with a very hard gel coat top.
Any experience?
Seems to good to be true as the look is great, cost is a fraction of granite..and it workable.
In Canada its made by and known as Mr Marble.
Re: Cutting "Man Made Granite /Marble
Paul Blackwell
I've cut Corian which is a man-made material. I made a serving tray from the cutout for the stove top. I just used a carbide blade in the tablesaw, and also in the router to cut a groove around the edge of the piece. This was 1/2" thick material, and other than using a slower feedrate, it was no problem to machine.
Moses Yoder
Moses Yoder
Corian is a type of plastic I think, different from the faux marble that Mark is talking about. We have cut lots of corian with regular woodworking tools and routed parts on our cnc router with a slightly slower feed rate than regular wood parts. I have never cut those faux marble vanity tops but have installed a few. I would probably put a cheap or old saw blade in the saw and see what happens. It should probably be a fine tooth like 40 teeth or so crosscut blade, not a coarse rip blade. You want a feed rate fast enough to make chips, not so slow that it heats up and melts the plastic and gums up the blade.
If you are talking about Corian or one of the similar high density plastic materials, I think you can cut it with regular woodworking cutters and blades with no problem.
If you are trying to cut "cultured marble" which is a mix of marble dust in some sort of plastic binder, I am not so sure. I have cut it with an abrasive blade, but never tried a saw blade. I suspect it will be very dusty and tend to ruin the blades and cutters quickly and may infiltrate bearings and wear surfaces. Not what I would want to do on my machines. Use borrowed machines and you may be fine. Until they find out what you did.
George Koch
Mark, I've cut many of the cultured marble vanity tops to length by using a diamond blade in a circular saw, cutting from the back side and out of doors because of the dust created. The cut cannot be polished to become a finished end or edge. As others have said, if it's a more plastic product, like corian, it can be be worked with normal woodworking blades an bits. George
Hal
If you're talking about the cultured marble, I used a masonry blade in my table saw and it worked fine. This was on the advice of the manufacturer. Dunno about routing an edge, but I think it likely a regular carbide tipped bit would likely work. Good luck. Hal
