Burning pine in stove question?
My son has taken down the trees in his yard. Two were pines. Would you burn the pine perhaps mixed in the hardwood or trash it? If you would burn it, is there anything to know?
Re: Burning pine in stove question?
steve mackay
Personaly I'll burn anything except plywood thats marked with warnings. The california warning comes to mind. Anything else is fair game. My standard is to touch the pipe before I chuck more in. To hot to hold your hand against it ? wait a couple minutes before stoking.
Thomas S Stockton
Barry
Pine burns fine and doesn't cause any problems that I know of. I don't tend to not burn it because it doesn't burn all that hot and there are a lot of other options available to me.
Tom
Re: Burning pine?
Be very sure to have your chimney and flues thoroughly cleaned at he end of the season. Pine, fir, and spruce burn fast but cool and contain a lot of pitch and creosote. The combination will load up a chimney and lead to a chimney fire faster than anything else. Personally, I don't bother with them because, like poplar, the low BTU content isn't worth having to haul in the wood and take out the ashes.
ditto
Bill Tindall
Re: Burning pine?
Thomas S Stockton
My stove pipe needs to be cleaned twice a year no matter what I burn in it. What matters more is how hot the fire is. When we first got our current stove we would have larger cooler fires and I had to clean the pipe more. Now we usually burn smaller and hotter fires. Most the fir we burn is douglas fir and it burns fairly warm and leaves less ash than oak and not a lot of creosote.
Tom
Re: Burning pine?
Bill Howatt
I agree. My experience is based on fireplaces and I didn't find pine worse than ohter woods but the fire had to burn hot.
Bill
Re: Burning pine?
FredD
What Mark says is good advice, every Winter I see house fires in the paper caused by a fire in the Chimney , first question out of the Fireman , is when did you clean your Chimney last.
We have a Chimney Sweep inspect and generally clean it on his recommendation every other year, one of the rentals has a beautiful Stone fire place and several tenants have burned trash, Pine , Paper,Construction wood and two even didn't know to open the damper first.
In our place we burn Osage Orange which has a higher BTU rating then Coal.
FredD
Wood is wood
Tom Dunlap
Keep your flue temp high enough to volatize the cresote and get it outside before it condenses.
Rick in Colgate, Wi
Lots of water in pine, about half its weight when its fresh cut. Let it season a few years and you will get a nice hot fire out of it.
Types of pine
Around here, one of the common yard pines is Monterey pine. I'm not sure how broadly this particular species is spread around the country now (I'm told that radiata pine, much of which is grown in New Zealand, and one of the materials used for inexpensive siding, is actually Monterey pine by another name, so it has been spread out somewhat). If what he had were Monterey pines, he shouldn't waste his time: hard to get burning (oddly) and very little heat.
Otherwise, I concur with some of the other folks: he may put in more calories cutting and splitting it than he'll ever get out of it in the stove. And it's got, if I recall correctly, a relatively high ash content, which means yet more calories schlepping the ashes out.
How clean and pretty are the trunk sections? Any chance of finding someone with a WoodMizer to make it into lumber?
Years!!?
Bill Tindall
Pine dries faster than anything. Of course not much left after it dries but I don't waste something that blows down. If I cut a pine in the spring it will be as dry as it will ever get by fall. Location is TN and I have daffodils coming up, and it was in the teens here last night.
1 more opinion
jcousins
we have yellow & digger pines - i don't go looking for it as firewood - but windfalls or hazard trees are cut and split - then left to air dry for 2 years. these pines are pretty pitchy and cause a lot of build-up in the flue. and as some have said - not a lot of btu return for the work.
jerry
