Is It Possible?
Is It Possible?
Is It Possible?
Doug Reynolds in Seattle
I need to cut a typical card scraper into half-inch strips for a special application. Is it possible to buy a metal cutting bandsaw blade and mount it in your standard 14 inch bandsaw to cut hard metal like this on a one time basis without needing a new bandsaw afterwards? Seems most metal shops wanted upwards of $100 for such a task. What do I need to do for lubrication and chip removal? Any other hazards to be aware of? Or, should I just pay the metal shop? TIA, Doug
Re: Is It Possible?
Re: Is It Possible?
Keith Newton----Little Rock, Arkansas
I would use an abrasive wheel on the TS, along with a Koolmist, to spray a fine mist right into the cut, to keep from annealing. You should be able to buy the blade for around $5, and the mist unit for ~$30.
After you are done with this project, you will love having it living on your grinder, and like me wonder why this isn't something in every woodworking catalog sold along with all of their grinders.
Re: Is It Possible?
Too thin to saw on bandsaw.
Virgil Johnson
When sawing steel on the band saw there is the "3 tooth rule" meaning 3 teeth need to be in contact with the metal to keep from shearing off the teeth due to the material being jammed into the gullet of the blade. If the scraper is .025 thick you would need a blade with a pitch of around 125 teeth per inch. Shearing the metal would be easiest provided it is not too hard. Borrow a friends table saw if you go the abrasive and coolant route.
Re: Is It Possible?
Re: Is It Possible?
Bruce, a MN Galoot
I'd be surprised if you could find a bandsaw blade that would cut the hardened spring steel that is most card scrapers. I'd get a skinny wheel for your angle grinder or a little cutting wheel for your Dremel, score a line and break off the piece. Clean up the edge on a grinder, refine that edge with a file and you're good to go.
Re: Is It Possible?
Re: Is It Possible?
Phil Joines
How accurate do you need to be? You can free hand them using either an Air cutoff tool if you have compressed air or an electric rotary tool with the fiberglass cut off wheels. The metal is hardened, with a bit of practice you can score them with the abrasive wheel then snap them off like cutting glass.
Re: Is It Possible?
Re: Is It Possible?
Dick Coers
If you could slow down the saw, and use a bi-metal blade, I think it would work. Scrapers aren't that hard, since you can sharpen them with a file. I know guys that use hand saw steel for scrapers, and I know they aren't hard steel. I also agree with the tooth count info, but I'm not a stickler for rules. Just my opinion though, please don't call if you wreck an expensive blade.
Re: Is It Possible?
I should have mentioned,
That I always use my little contractor saw for cutting or grinding functions like making shaper knives, or sharpening planer and jointer knives. I wouldn't have a problem using either of the other two saws, except for the trouble of cleaning out all the pockets of dust.
Also there is a additive for the water, that inhibits rust, which is non oily, and safe to use.
Re: Is It Possible?
Re: Is It Possible?
Doug, I am not a metal worker so I would approach this with trepidation.
First, I found a retired metal worker who has a shop with lots of equipment. I am not sure how much work goes on there anymore, it appears to be his man cave where he and his buddies sit around and discuss metal working, more than doing it. I have gotten him to do a number of small things for me and he was very reasonable. Charged me inconsequential amounts for cutting up saw blades and making faceplates. I would look around for such a guy if I were you and let him cut this up for ten or twenty bucks.
If I were going to cut this myself I would use either a Dremel or some sort of angle grinder. I cut some copper tubing on my bandsaw the filings got everywhere and were very difficult to get out of the tires and a real mess. Extreme danger of getting it in your eyes. Also the blade runs about three times as fast as it should and he teeth are way to large.
Another thought. How about taking a bandsaw blade and breaking or cutting it to the length and using the back side of ti for your project? Find somebody with a Woodmizer type saw and they might give you a worn out blade.
Re: Is It Possible?
How about a hacksaw?
Jesse Cloud
Re: Is It Possible?
No
Just to answer your question directly, your wood-cutting bandsaw runs much too fast to cut ferric metals.
On a personal preference note, I would not use an abrasive disc in my table saw. The super-fine abrasive dust can "waste" your arbor bearings.
Re: Is It Possible?
If it were I . . .
steve mackay
( and I'm probaly missing something ) I'd strip it with my Dremel (with cutting wheel) then run edges on the bench sander to straighten them up.
Re: Is It Possible?
Re: Is It Possible?
Joe Mohnike
Take it to your local high school metal shop, They may have the equipment and a student who can do this as a project.
Good Luck
Joe M.
Re: Is It Possible?
Re: Is It Possible?
FredD
A piece of cake if you or a friend own a Milwaukee Sawzall.
They make a blade with the cutting edge coated with Carbide particles that would easily cut the Scraper steel. This a reciprocating hand held saw if your not familiar with one. The saw is variable speed in one model , so run it slow.
Since the steel is thin , to keep it from jumping back and forth with the blade , clamp blocks of 1/2" thick or so wood on each side of the cut and on both sides of the Scraper.
I have cut nearly everything hard with that blade , it does a cutout in a Ceramic Tile backsplash set in mortar like cutting Cheese and that is a nearly impossible cut any other way.
FredD
Re: Is It Possible?
Same here
John in NM
Easiest way to go. I do like Barry's bandsaw blade idea though, they're easy to break to length and grind the teeth off.
Re: Is It Possible?
My solution
Based on all the fine Woodcentral advice, I made contact at a local machine shop and was allowed to cut my card scraper into half-inch strips on their bandsaw myself at no charge. Only needed about six strips so, it took just a few minutes. Thanks for all the advice about not using my woodworking bandsaw for the job. I sure didn't want to ruin it for good just to try and save a few bucks.
Re: Is It Possible?
Re: What is this for?
Keith: I took a spice box class from Steve Latta at Marc Adams School of Woodworking. Steve decorates the doors with traditional line and berry inlay which he executes with inlay tools now available from Lie-Nielsen. In the class we made our own tools with cutters made from a card scraper. Steve teaches at the Thaddeus Stevens College and has access to the metal shop where he got the class' blanks cut. I wanted to make more tools and needed to cut the card scraper into thin strips about 3/8" to 1/2" to make the cutters. The Lie-Nielsen youtube site has Steve demonstrating how to sharpen the cutters. It was a great class and now a friend and I are making nine of the spice boxes as gifts for our families.
Re: Is It Possible?
I was just curious. I started carving back in the sixties, before becoming a carpenter, which led to working in a shop before 1970. Back then, I didn't have access to a lot of catalog suppliers like today, so I made a lot of my early tools from whatever was available.
Back then, before bi-metal, hacksaw blades were good steel to turn into little background scrapers, as well as jigsaw blades.
Now one of my favorite re-cycle blades are the little disposable blades for planers. This is really good steel, with just enough thickness for support on short unsupported blades, yet quick sharpening.
I cut them in half, dull the cutting edges down the length of both side, then sharpen both ends like I would normally sharpen a chisel. I like to grind hot enough to get the tip red, so I can roll a burr without it chipping, rather than annealing the whole blade.
For a lot of cleaning up of detail work, I like just a very slight arc across the end. but at other times, more of a fingernail shape. Getting toolrest out of the way, this is my favorite last cutting tool on the lathe, before sanding.
