We value your privacy.
I am finishing a slab of Black Oak that is about 200 yrs old. I have sanded it and am about to spray a water based poly on it. I will not be staining leaveing it natural under the poly. Should I use a prestain or a conditioner and if so which one. I have some minwax prestain but have only used this on pine.
I'm no finishing expert but if you're not staining and you're spraying an absolutely clear topcoat, what would be the purpose of a prestain? I think they're typically only for use with oil-based stains, at least that's what the can I recently used said.
Greg, a prestain or conditioner is not necessary in this case. They are generally used to inhibit stains or dye from darkening end grain and help prevent blotching on the surface. Since you are only applying a clear coating, a conditioner is not needed.
I did use the wood hardner and it did change the wood color. I only used it in the decaying center area so it did not affect the much of the visable area.
