We value your privacy.
I have a Jet cabinet saw with a 52 inch sidefeed table. In the interest of saving space in my shop, I considered using the sidefeed as a router table. Has anyone done this? Pros, cons? And are there plans to do this? Thanks.
When I started WW'g I replaced one of the cast iron wings of my trusty Craftsman TS with a router table.
I won't say it didnt work and for basic edging or rabbeting which was the only type of work i was capable of back then it was fine
However it had many limitations I had not forseen in my design .... so consider some of these in your design .
Table Material: The table on a router table needs to be solid and sag proof otherwise accuracy and performance will suffer..dont cheap on the table, make sure if using the existing side feed it is stable enough
Fence. Having a versatile fence system is a must for a good Router table IMO. Adjustable opening for different sizes of bits. Higher fence, ability to attach clamps, jigs, feather boards. On mine I had to clamp the fence for each setting/position which was a pain and hard to dial in accuracy.
Mitre Gauge track: Can you still use the table saw mitre gauge/ if not the router table's use is now limited from some operations like rail and stile bit sets that need a sled.
Size of the table itself, doesnt have to be huge but bigger is better.
For me in the end a dedicated router table that was solid flat and fully accesorized was the way to go versus my table saw experiment.
Re: Table Saw side feed conversion to router table
I have a router inserted into the wing of my TS. (An old Delta Rockwell contractors saw with a Biesemeyer fence). Also because I don't have room for a separate router table.
Mine is a slightly crude home-made setup. Two plastic laminate sink cutouts form a counter top, glued together back to back and installed as the wing. Installed bolts on the edge during glue up to allow it to be bolted to the wing of the saw. Cut a hole in it to drop the router in. Just used a piece of hardboard as the insert to support the router and used an old Stanley router I had. I like it and get a lot of use out of it from time to time. Just bought one of the discontinued PC routers from HD to possibly install in it.
I thought it would be handy to be able to use the TS fence for the router and it is, BUT it always seems I want to use the fence for the TS while using the router. So, I am skeptical of the dual use fence and would not recommend it.
You can make or buy a fence designed for use with a router and that would be an improvement. But then you have to store it when not in use. And I am cheap and poor at the moment, so investing in an occasional use fence is questionable for me at this time.
A router lift could be a really nice addition, but I am cheap and poor...... Actually, it might be like an ice maker, seems like a total luxury until you have one and then you wonder why you didn't do it sooner?
Dust collection is another issue, but that could be incorporated fairly easily. At this point you have built a router table that is built into your TS. Not a bad idea. The only disadvantage would be that dual use thing. For example, you would have to retract the router or remove it to cut large pieces on the TS, but for me that does not come up nearly as often as wishing I had two fences. Dust collection is a conundrum for me because I park my Performax drum sander under the wing and there is not much room left. (does that make this a triple use problem? Ah, the small shop blues are playing in the background.
Eric
The Jet has the standard cast left and right wings with the aftermarket 52" wood (pressboard or ply) sidefeed with a formica topskin. I realize I'll need to stabilize the table to avoid any sagging. I guess adding a T-track mitre slot would be a good idea too. I'm not loaded $$ but I don't mind spending the money to do it right. Also considered adding a lift. Are there any plans available for this type of conversion?
Run - don't walk - to Amazon and order the Bench Dog cast-iron extension. I have had mine for a few years now (right tilt Unisaw), and have always been very satisfied with it's performance (both table and fence). It will also extend your table saw ~8" to the left of the blade -assuming that it replaces your left extension table - which is always "a good thing".
I added a router to the right side of my Jet. I have a 2hp dust collector which is located near the TS. I have a shark guard blade guard with 3" dust hose. I have a 4" hose to the base of the TS. My router fence allows me to switch the dust hose from the saw to the router fence. I have a big box built around the router. I switch the 4" hose from the base of the TS to the router box. The result is excellent dust pickup for the router. I agree with the separate router fence.
Re: Table Saw sidefeed conversion to router table *LINK*
Robby Wright in San Marcos, CA
Like Barry, I have an old Rockwell Contractors Saw. I just upgraded my router table on the left side of the saw. It would have been better to put it on the right, but space won't allow it. I posted about it under weekend accomplishments - Link below.
I can totally appreciate the Bench Dog wing table idea. But after adding a lift I'll be looking at $400 in accessories. It's a little more than I wanted to spend to be honest. As for dropping it into the right side of the sidefeed table, everyone seemed to agree to have an independant fence. Are you guys suggesting a complete fence assembly completely seperate from the Biesemeyer, or are you talking about creating/buying a fence that essentially pads out the TS fence to create a zero clearance w/dust port router fence? Also if anyone has a link for plans, please add the link. Thanks.
Jim Dillon
Eric,
I've been very pleased with my router mounted in my cabinet saw extension table. Below is a past WC thread that shows a picture of my separate homemade fence, plus many other excellent suggestions by others for doing what you would like to do.
I would reinforce the bottom of your stock tabletop to prevent sagging. I built my extension out of 3/4 inch MDF, but more importantly to you, I reinforced the tabletop with 1x4s (actually 3/4 x 3 1/2) underneath to create sort of 1/2 of a torsion box. I surrounded the area where the router would go with additional 1x4s making sure I had room for the router.
As an aside, I was also able to hang several storage shelves from the 1x4s for storing my TS fence, fence fixtures, wrenches etc. This has worked out really well and, as it is suspended, I can clean under it.
Try the Woodcentral search function to get more input. I entered "extension table" and got a lot of hits, many dealing with what router to use.
One more thing. I think a recent issue of FWW had a nice homemade router fence that used the TS fence, although I don't recall that it had separate sliding faces. Yet one more option for you to consider.
Eric - I have always had my router table fence separate from the tablesaw fence. Invariably, as soon as I get the router table set up, I have to rip something. Using the same fence for both would require that the fence be reset, the rip made, and the fence reset back.
Another thing to look at is that some tablesaw fences, such as the Beisemeyer fence, aren't secured at the back of the fence, allowing it to lift up from the table. This can cause some serious problems.
Although I added a miter slot to my extension table (not in the table per se, but attached to the end), I have never used it in 15 years! If I was doing it again, I would not add it. I simply find it easier to use a backer block to support the work piece and slide that along the router fence. This avoids tearout as well. But, YMMV, as they say.
I too have a large right side table on my TS. When I bought the TS used there was a router plate there; eventually I replaced the top board of the table (melamine) as well as the router insert plate.
I like the setup, because it gives me a sizable table surface. Typically I have the router fence set to the TS blade side of the bit and feed material from the bask of the TS to the front; if I need a larger router table area, I set the fence on the side of the bit away from the TS blade, feed material from front of TS to back, and I have the entire TS surface area to support the piece (once I remove the fence and drop the TS blade). Not often, but I have done it.
I have used a router fence tied my TS fence, but that is not the optimum. A free standing router fence is much easier. Mine is simply scrap 1x6 oak; L shaped, one piece as a base, one perpendicular, and a few backer blocks. I simply clamp on each end with deep throat vise-grip clamps.
Remember that for a router bit does not have a plane like a circular saw blade (TS, miter saw, etc); the relationship of the fence to the bit determines the size of the bite of material removed, but the fence does not have to be parallel or perpendicular to anything else (unlike TS etc).
I do not have a track in my table and have never missed it. I generally use a shop made sled and use the fence as a reference surface.
For setup reasons I chose to build a portable router table. When I need the router I set it on the table saw extension table. If I need to cut something wide on the table saw I just simply take the router table away and set it somewhere else till I'm done. This way the router and the router fence settings never get moved.
