O.T. Rust question
O.T. Rust question
O.T. Rust question
Edward in Vancouver
Although I am a bit of a lurker, I've been enjoying these forums for quite some time.
My question pertains to a p.o.s. at work that I have named "Pinto" a chinese baker's deck oven. Tis is a two-pan oven with a 8" crown, meaning the interior is 8" high and can accomodate two 18" x 26" sheet pans.
The problem is rust. The ovens (there are two of them) -though in good shape--have no steam vents, and as a result of several years worth of baking, the insides have started to rust and the flakes are becoming a hazard. The inside is constructed of sheet metal, with the deck, or base, of heavy guage sheet metal. Althogh I've switched to using the top deck oven, I know I'll have the same probelm in a while.
My first plan of attack is to install some kind of a steam vent or gap so that moisture released during baking can escape. Fair enough.
The second involves removing the rust so it doesn't fall down during baking. In the past I've cleaned it with a damp rag-on-a-broomstick, rubbed in various oils and fats on the back and walls, and vacuumed up the rust. But like Neil Young sings, rust never sleeps.
Q: There are several products on the market for automobiles that "convert" the rust into black rustproofed metal. I'm assuming this is some kind of oxolic acid which I know can be toxic.
If I were to spary this stuff on and then later crank the oven up to say, 450 F, I know I'd invariably get some of the stuff on the top heating elements. Would the fumes be toxic?
For now I'm using the top deck oven but it is a p.i.t.a, and I'd rather use the bottom deck, but can't until I've got the rust problem licked.
Suggestions?
Regrards
Edward
Re: O.T. Rust question
I can help a bit
Bill Tindall
I can help with one detail. The rust conversion stuff is phosphoric acid and the product will be iron phosphate which is black, and with luck adherent. One baking cycle and the residual phosphoric acid will bake off harmlessly but it may well smell and have an irritating odor.
No doubt there is other stuff in the formulation because it is more viscous than just a solution of phosphoric acid. No idea what it may be but I would presume it too will bake away anything volatile that could affect taste. I would run the oven to its max temperature (600 F would be great) so as to form what will be a more stable oxide layer on the iron which may offer portection.
In the end you will be buying a new oven because once what ever prortective layer was on the metal is breached I doubt anything will provide permanent protection against steam.
IMO, you need a new oven that is properly vented (and with an intact interior enamel). As Bill said, some of the rust converters are phosphoric acid based. They provide a good "base" for subsequent painting or coating. You may want to look into grill paint or a high temperature coating.
I'm not sure about the local supply of used restaurant equipment in your area. I picked up a Vulcan double convection oven and a proofer/warmer for ~$1000 for my church. If you look around you may find similar deals. As I said, I would vote for a new oven.
Edward in Vancouver
Thanks for the information, gentlemen.
Phosphoric acid? if I don't know any better, isn't that one of the "secret" ingredients in Coca Cola?
Engine paint is something I never though of. Might be worth looking into.
My business partners are uh..."reluctant" to spring for new ovens at this time, so I should milk as much time as I can out of these ones.
Vulcans are decent ovens, I prefer Blodgett myself, and can't say enough about convection ovens for cooking and catering, in these areas they are true work horses.
Problem with a convection oven (ALL ovens have weaknesses) is that you only have one temperature zone. This is not a problem for panned bread, and conv ovens work great for this too. For pastry items convect ovens are not ideal. OTOH, with deck ovens you have individual top and bottom heat settings, as well as intensity settings. You can dial in crispy bottoms and pale tops or any combintion you want.
not in my muffins please!
Bill Tindall
Somehow painting an oven used to bake food with paint designed for an engine or wood stove just seems like a bad idea. The problem is that paints are complex formulations and it is unpredictable what stuff of concern they might decompose to under food baking conditions. It is one thing having harmless ferric oxide flake off into the muffins, quite another degraded paint chips.
yes, cola drinks contain small amounts of phosphoric acid
If you like Blogett, I'd suggest you call them (or your oven's maker) with the issue as they have certainly dealt with it before. It might not be beyond the realm of possibility that your oven can be relined with a new part cheaper than buying a new oven. Either way, your partners need to confront their "exposure" to a customer becoming ill or injured because food becoming adulterated by the condition of the oven.
Water/steam when heated much above the boiling point (as it is in baking and roasting) becomes pretty corrosive as its effects on metals is increased. While high temp paint may do well on the dry exterior of a grill or stove, its resistance to super-heated steam would be compromised. I seem to remember that commercial ovens use an aluminum coating or plating on the interior surfaces so that it "weathers" to a very durable aluminum oxide layer.
Phosphoric acid (the active ingredient in naval jelly) chemically converts iron oxide (rust) into iron phosphate, a dark crystalline compound that forms a thin coating that is resistant to further oxidation. Again, however, its life expectancy in the presence of 300�+ water vapor is questionable.
Not much help with your problem, I'm afraid, but your options are pretty limited I think.
