OT- Trailer Hitch
Thomas Norton
I would like to install a hitch on my wife's Honda for a bike rack. Does anyone have a source for hitches and would you know if the frame is already drilled?
Thanks!
OT- Trailer Hitch
Thomas Norton
Thanks!
Re: OT- Trailer Hitch
John McGaw
It would probably matter a lot what sort of Honda you are dealing with. A Fit? A Ridgeline? Something in between? In looking for aftermarket hitches for other vehicles I've seen situations where one maker required frame drilling (sometimes welding too!) and another maker didn't -- same car, different approach. If the vehicle is fairly new you might do just as well going to Honda for the hitch if they offer one. That is what I did with my Subaru Outback and now I' have a hitch which they guarantee to work properly with the rest of the vehicle.
Dave Paine
Try a Google search for "car hitch". Large number of hits.
A local UHaul store will likely sell and install.
Lots of mail order if you want to install yourself.
Many of the sites will likely state if the specific model has the mounting holes.
For a bike rack no need for wiring, but if you want to pull a trailer, also try to find out if the wiring already has the connector, otherwise have to get special splice connector.
Dale Stansbery
I can't answer your question, but I was able to find all the info I needed for installation on my 2008 Jeep as well as best prices through Google and Ebay. You should be able to as well for your car.
Friend of mine has a bike rake one the trunk lid of her Civic and a Canoe rack on top of the Jock-mobile. Neither required attachment to the frame. The rake on the trunk has two foam padded arms that stick out to the rear far enough to support several bikes. It makes the lid heavy and it will barely stay up on its own and if you are not paying attention the arms will knock you silly if you slam the truck or allow it to slam.
Chuck in Mtl.
A hitch for your wifes car should be a straight bolt-on. Check on line for the model of hitch needed at reese or Hidden Hitch or Drawtite. They can provide details.
Tates in Chesterfield, VA
I have purchased a couple of hitches on etrailer.com. They have answers to all your question on how to and what to purchase. Lots of instructions can be found. I am only one of there satisfied customers.
Tom
second etrailer.com
Jerry Gibbs
Re: OT- Ditto etrailer.com
Carol Reed, Strawberry, AZ
