Rail and stile raised panel question....
Jesper, Denmark
Jesper, Denmark
Typically, traditionally and probably also for some practical reason, raised panel doors with rail-and-stile construction have the stiles (vertical) go all the way through with the rails mounted in-between.
I am building a raised panel with 5 fields as a backsplash to a counter. Using the traditional condtruction, all the stile ends will show at the top. I would prefer to reverse the construction, so the top and bottom rails go all the way through and the stiesl in-between. The ends of the rails will only show on one side, as the other side is covered.
The panel dimension is 20" tall and 5 foot wide.
Commentary as to the looks or anything I might have missed are welcome.
Re: Rail and stile raised panel question....
charlie belden
Normally rail and stile with panel have the vertical members continuos for structural reasons. With your horizontal application that's not necessary so you can do either way.
I'm not sure a raised panel back splash is very practical - if there will in fact be some splashing.
George Koch
This is the way it would be done if it was a wanscoting, and it also gives you half as many exposed joints. George
FredD
George has it right, though why it being used as a backsplash is another subject.
FredD
Bill Wilkinson
Kitchen cabinets upper doors have their ends of the stiles above and below eye level, thus the endgrain of the stile is not visible.
I suppose that endgrain is less desirable to be visible.
I would think long and hard before I used a frame and panel as a backsplash - water infiltration could wreak havok
