Audiophile Input Request
charlie belden
This is a piece I'm working on and need some feedback / suggestions from anyone
who knows about speakers. I think it'll work but it no doubt can be improved.
Re: Audiophile Input Request
Jesper, Denmark
Re: Not  an audiophile, but........
Jesper, Denmark
I think the concept will work. I am a bit sceptical about the styrene foam plate as the diaphragm, though. I think it will be too soft and will attenuate the vibrations, so they do not reach very far from the vobrator.
Something light, thin and stiff seems to me to be reqy�ired. Thin aluminum sheet comes to mind.
Note that the softish audio speaker diaphragms are not fixed at the outer edge, but arraged so they can move freely. Also the cone shape provides stiffness, where your diaphragm of necessity is flat.
charlie belden
I somehow have to seal off the micro balloons so they don't get into the works as it were.
As for the styrofoam, I know it has been used for flat speakers that use a transducer to vibrate it in order to make sounds. I may6 replace the vibrator with one or more piezo electric buzzers, again, pulsed to create different tones and patterns in the micro balloons.
Bill Earl
I don't think the inner ring of foam tape is necessary. It will probably just damp most of the vibration from there to the edge of the diaphragm.
Not sure what effect you want to achieve, but piezo transducers aren't going to give you much low-frequency energy & any vibrations will not propagate very far from the source.
Pager motors will be almost exclusively low frequency. For a wider range of frequencies, you might consider using the motor-assembly of a small speaker.
What kind of microcontroller did you have in mind to drive this?
Re: Physics *LINK*
Morning Charlie,
You take me back to the high school physics lab where we did experiments with a standing wave generator. Those, of course, were done with a water surface and movable vf "generators" (buzzer arms hooked to rheostats).
I suspect you're going to have some serious damping issues both with the wood bowl and your mini balls. The entire bowl will vibrate based on your design, same as the internal cone of a speaker, rather than acting as a speaker cabinet. That will likely result in much of your energy being dissipated rather than being focused on the vibration plate. This is why speaker cones are suspended in a frame that is then fixed in a cabinet. I also think the large amount of air between the balls will also work against you. Air is a relatively poor sound (vibration) transmitter compared to a liquid like water, and a lot of energy will be lost at the interface between the air and the surfaces of the little balls, so you're likely to need much more energy than your little buzzer can put out. At the very least, you should think about suspending your design unit inside a different "enclosure" that will allow the bowl the vibrate, or suspend your plate inside the bowl so they are independent of one another.
Lastly, if you're looking to make varying patterns in the surface, you should consider more than one vibration source.
PS: There are a bunch of videos on You Tube about this, so you can take a look. The link is just one.
Standing Waves
Jesper, Denmark
Re: Superman!
Jesper, Denmark
charlie belden
I'll be using some version of the Arduino and the Pulse Width Modulation (PWM) available on several of its pins to change frequencies. The effect I'm after is to cause a stryofoam closed cell picnic plate with either a cell phone vibrator or one or more piezo buzzers double back taped to its underside to vibrate - and to vibrate very small, very light glass micro balloons to "dance" - hopefully in interesting wave patterns.
The little cell phone vibrator (a small motor with an eccentric weight on its shaft) will, as you noted, produce low frequency at greater power than the alternate piezo electric buzzer(s). The vibrator motor will consume more power while operating. Since the vibration mode will be of short durations and occur intermitently - spending most of the time OFF.
wilbur
I guess the question is, is the primary goal of the project to make something that will generate pretty patterns in your micro balloons, or to make a functional speaker? If it's the former, it will work almost no matter what you do. Whether you center the cell phone vibrator, deliberately put it in an eccentric position, or have two or more cell phone vibrators, interesting patterns will result.
If you are looking to make a functional speaker, though, it probably won't work very well, unless you're looking for AM transistor radio quality.
Bill Earl
Sounds like a fun project!
You should be able to vary the pager motor speed (and resulting vibration frequency) over a moderate range using PWM. The key issue is whether you can hit one or more of the resonant frequencies of the system to produce interesting standing-wave patterns. But if your syrofoam diaphragm is sufficiently flexible to begin you should be able to easily influence the vibration modes with the addition of small amounts of mass in strategic places (like bits of tape on the underside)
The output of the Arduino PWM ports is limited to about 30-40mA. You will probably need an external transistor to drive any but the smallest of motors. Most any general purpose NPN on the low-side should be up to the task.
So Far So Good *LINK*
charlie belden
Well, with a little modification to the set up I posted initially - the foam picnic plate was cut to fit and "persuaded" into position in the bowl. Taped the cell phone vibrator to the underside and powered it up with a 9V battery. Got a somewhat annoying and surprisingly loud sound - and a visibly vibrating diaphram. I added about a shot glass worth of birdshot to the top of the diaphram - and the little shot bounced around like fleas on a hot plate. But covering the entire diaphram with birdshot to a depth of two layers was too much for the little vibrator.
And once again -Serendipity. There were some small turning chips of african blackwood in the birdshot. They stayed when the birdshot was poured out of the bowl. Small and light, these little chips were easy to bounce around on a vibrating surface.
As luck would have it, I'd saved zip lok bags full of lots of small chips of different colored woods. I'd intended to use them for a piece that poked a bit of fun at Art Speak. Holes became "negative space" which in turn became "the presence of absence". I was going to make piles of the different colored woods and titled it "The Absence from the Presence of the Abscence "
When I dumped some of the african blackwood out of its zip lok bag onto the diaphram and powered up the vibrator I was encouraged. This idea looks like it'll work! Have to figure out how to stop the annoying sounds the vibrator makes but I'm hoping that pulsing it will take care of that. But I'm also looking for a smaller vibrator or a small transducer.
A customer at my local RC Hobby Shop overheard me asking a store clerk for a smaller vibrator motor and told me he had a bunch of them smaller than the one I'd brought as an example of what I was looking for.
AND - the ones he had a bunch of came with three hearing aid batteries - in a battery case - with press On/Off switch.
THAT'S EXACTLY WHAT I'M LOOKING FOR. Where'd you get them?
A "novelty store".
A "novelty store"?
You know - an "adult novelty store".
SAY WHAT!?
Vibrators. Where else would you look for small vibrators?
So I'm thinking. I walk into an "adult novelty store" and tell the guy behind the counter I'm looking for some really small battery powered vibrators - for an idea I'm working on- to get a turned wooden bowl to act like a speaker - and bounce wood chips around in interesting patterns - controlled by a little micro computer the size of two pennies layed end to end . . .
Now I'm willing to pursue a Wild Hare Idea - up to a point. But . . .
Annway, attached is the url to the YouTube video of where this Sound Visualization Bowl idea is at
Vid of Singing Bowl Vibrator Idea
Re: So Far So Good *LINK*
Bill Earl
You might try a small speaker as a transducer. You will be able to control both the frequency and amplitude over a much wider range than with the motors.
The link is for a 1 1/2", but I have seen them as small as 1".
Just glue a chunk of styrofoam to the center of the cone (thick enough to clear the flange) and stick that to the bottom of your diaphragm.
miniature speaker
