Veritas - Innovation in Tools
Glue for Car Bumper ? OT
Actually got the car back on the road today. Thanks for all the help from Wood Central.
Another question: The Honda has a big black plastic front bumper. There are holes in it for Fog lights. I need to fasten something into those holes, I don't have fog lights. I cut the sections that match the holes out of the old bumper. Now the question is how to fasten them. I don't know what the bumper is made of, but does anyone know if there is a glue that will permanently fasten the blanks into the holes?
Re: Glue for Car Bumper ? OT
PS, I tried glue....
for plumbing pipes such as PVC and ABS. Did not work.
Plastic appears to be polypropylene.
Black weatherstrip adhesive
Phil Joines
Re: PS, I tried glue....
Keith Newton----Little Rock, Arkansas
If you are in an area where there is a good marine store, you could probably find some good caulk type adhesive sealers like 3M 5200, which comes in black. It is pretty expensive compared to most caulking tube, and is slow to set, but sticks better than most high viscosity products, and is totally water proof, and holds up in the sun.
You might be able to find black silicone cheaper, and the newer stuff seems to stick better than it once did.
Both of these products will work better with a fat joint, rather than thin.
Jesper, Denmark
Jesper, Denmark
Yuo can probably get a similar RTV adhesive from an auto supply store in smaller tubes than the 5200 at a lower price.
mark nowicki
Why not put in a pair of pretend fog lights?
You don't have to connect them.
Mark
I thought about that, but fog lights on Ebay were close to fifty bucks. I think I will go check again, that seems like a lot.
Ken Oakley-Sunny St. Cloud, Fla
Jam a couple of tennis balls into the opeings. Only cost a couple of bucks. Could even paint Smiley Facs on them.
These are sort of elongated holes, squarish on one end and anglar but rounded on the other. I'm thinking a piece of walnut might do nicely.
BrianA
I hit a hunk of ice last winter with my Honda Accord. Big chunks came out of the bumper and it was hanging down. Got home and use JB Weld to piece it all back together. It has been holding up fine for a year. My wife hates it but it was fixed for free.
Brian
In PA if you have aftermarket
Gary Smyth
lights installed they have to work or be removed. Once a year inspection only but the lights have to work.
