We value your privacy.
At one time, back during the Pleistocene I think, I was a decent photographer. I had an Argus C3 and a 9x12cm Voigtlander film pack camera. I just gave my C3 to my Grandson. My friend had a C3, a Crown Graphic, and the use of a Leica (prewar), a Kodac 35 and a top notch reflex camera.Boy did we have fun. Of yes, he also had a dark room - his parents were professional photographers.
Anyway, I now have a Canon Power Shot S3 IS on permanent loan from my son in law. Using it is no problem, but how do I download it to the computer? I know I need software and a USB cable, but what? I assume there is a special cable and I also assume that the software is easy to use. I have done some desultory looking on the net, but since I don't really know what I need, well .. .. ..
Call you SIL and get the CD that came with the camera from him. The cable you'll need is USB on one end and matches the output socket on the camera. That also should have come with the camera. If you're shooting in JPEG, Windows 7 will also handle the download, but the Canon transfer software will do a better job, and will allow you to shoot in RAW then convert the image files to TIFF format in you computer.
No special software needed. I use a USB card reader; remove the card from camera and insert into card reader. Some computer have card readers built in (my newer cheapo e-machines desktop does). The card then "looks" like any other disk drive and you can copy/move files from one place to another like you normally would. I typically move all pictures to my computer, then delete the lousy ones from there. I then re-insert the card into camera, reformat it to delete all previous pictures, and start all over.
Most times the camera comes with a CD of software, and a cord to connect to the camera to the computer. I consider these more complicated than necessary, especially if you use non-brand specific software to edit your pictures. Google's Picasa is a great free place to start if you have not done digital picture editing before. It is likely far better than the software that comes with a camera (although Canon's DPP software is also very usable).
You want a USB cable that has a regular computer size USB plug on one end and the miniature USB plug on the other end. The miniature one looks differently and is a lot smaller. You should be able to find one anywhere from Walmart to a computer store.
Software probably came with the camera that does basic photo-editing functions and you could ask your son about it. You can also buy programs like Adobe Elements, Paintshop Pro, etc or freebies like Irfanview and others. Google is your friend.
However, to just copy the photos from the camera to the PC when you connect the camera via USB and turn it on (some cameras may make you select the USB or export mode) the PC should recognize the camera; it will appear as a disk drive to the computer and you can copy files off it. Windows has some built in capabilities for viewing.
I'm sure others will give you some specific help, it would be good if you posted the type of computer and operating system version since not everyone has the same capability.
Replacement cords can be had, you just need to know the name of the plug on the camera end. I believe many are mini-usb, but the one on my cheapie camera is even smaller. You can probably take the camera into an electronics store or even a camera store (if you can find one! ) and buy the correct cord for under $20. You can buy them online from places like Tigerdirect for about $5, but you need to know your plugs to get the right one.
As Mark says, the camera should have come with a CD, and that is a good way to go if it works with your system. You can also download Gimp, an open source photoeditor that does a lot of amazing things. I've been told its not as easy to use as photoshop, but the price sure is right. My machines are running XP and linux, I don't know if Gimp has a version that works in Windows 7 yet, but their website should give you lots of info. You should be able to work with RAW and TIFF files using it, but some RAW files are proprietary and you might indeed need Cannon's software.
When one finally makes the change from film cameras to digital it is like starting all over, at lest it was to me when I did it about 15 years ago. I don't recall ever using a cord to transfer the images from the camera to the computer. I always remove the memory device from the computer and put it into a card reader which is connected to the computer by a USB cable. The camera that was given to you came with some software for handling the pictures. It may or may not be adequate for your needs. There are plenty of free software packages for handling digital pictures.
I would check to see if your camera giver still has the original CD of software. MY guess is that they won't be able to find it. You may be able to go online to the camera companies web site and download that software as a start.
So don't waste any time trying to figure out how to get raw.
If you can't find a Canon Solution CD, I'm pretty sure that you can download it.
There will be some functions on it that may not be on other software, like stitch mode. That is the only thing from it that I use since I use a mac, and everything else is easier in iPhoto.
I have had S3, S5, S10, skipped 15, now own S20, wishing for SX30, but something else will likely be out before I move on up, unless I loose or dunk this one.
The S series is incredible. I don't know why anyone who isn't pro, would want to tote around all the extra baggage of the DSLR's, when you consider what these little camera can do for the price. And actually, there are some things that may be better.
Keith, I have no cell phone and the LINK demands one. I tried to use my phone number and was refused. I also disapprove of the LINK being a sign up service for a charged phone e-mail type of thing.
Based on the age, the S3 probably uses a mini USB type B connection so you would need a USB-A to mini USB-B. Of course if you have a card reader on your computer you don't need the cable at all and can just read the memory card directly. All of the camera's software and manuals are available online directly from Canon.
As others have said, you don't NEED anything to get the photos on your computer besides a USB cable.
However, keeping track of your photos is an issue with digital photography. Since you don't have the film developing cost you shoot and shoot and shoot. Soon you have thousands of photos on your computer.
I highly recommen Adobe Lightroom 3. This application is excellent for keeping track of photos and editing them. It's a very popular application with a very large user community. You can add plug-ins to it, many of which are free.
The editor is very good, it's the same code as in Camera Raw of Adobe Photoshop CS5, which is pretty expensive.
�Microsoft� Windows� XP with Service Pack 3; Windows Vista� Home Premium, Business, Ultimate, or Enterprise (32 bit and 64 bit); or Windows 7 (32 bit and 64 bit)
�2GB of RAM
�1GB of available hard-disk space
�1,024x768 display
�CD-ROM drive
It's worth the $300, think of it as a tool that you'll use a lot, because you will.
Norman, I was given an inexpensive point and shoot digital, a Kodac. It came with all necessary software, so I also have Picasa 3 which I like. The problem with the P & S is that it is too similar, in use, to the old Kodac Brownie. In other words, too basic. However it has worked well as did the old Brownies. But when Tim offered me the Canon I jumped at the chance. I'd like to get back into photos again and the S3 IS is far superior to anything I've had previously. Being digital I don't need a dark room - I'm using the Dark Room (computer) while writing this!
I think the situation with GIMP is not that it is so hard to learn compared to Photoshop, it's that it is so drastically different from Photoshop. Someone was developing a GIMP "deweirdifier" but I think that project might have died out.
I have Photoshop CS2 (I got it free) but a lot of the simple photo editing and enhancing tasks I find XNVIEW to be perfectly adequate.
Here is a direct link to the Canon support page for your new camera.
You should be able to navigate and download anything you require from there.
The S3 is a great camera.i have/do own and S1,an S3 and an SX20.
What others have said is correct a USB to Mini USB will allow you to download pics off of the camera.A card reader can also be used,you just have to remove the card from the camera and insert it into the appropriate spot.
Robert you really took me back in time. I started in Photography when I lived on Okinawa (53' - 55'). All I had to do was buy the film and processing was free. My first camera was an Argus C3. During the same time I later purchased an Argus A4. I have never been able to capture black & white the same since the C3. The A4 was never as good as the faithful C3.
I just wish I could still use it although the Canon is unquestionably a much superior camera. I got mine in '48 or was it '47. Anyway, it was fun to use. That said, I also enjoyed my Voigtlander which could be used w/a ground glass rear plate as a portrait camera. It had no special features except a 3.5 lens, a film pack (which I used), and a roll film device. It was a bellows camera. For quick use I used a built in large wire (yes, wire) viewfinder. I git quite good at that and did some rather good HS football game photography, nearly as good as the Crown Graphic my friend had. I think the fastest shutter speed was 1/500 - not bad.
Kind of sad to see 35mm film become obsolete. Kodak has just about quit it completely. Loved my Pan X. I now have a Canon 20D, 40D, and new 60D. I use Photoshop CS4, Nik, Topaz, and On addins.
