Does This Sound Like A Belt Issue?
Steve in Phoenix
I installed a brand new Amana A.G.E. 80 tooth crosscut blade, and a strange thing happened. In the test crosscuts, the leading 1/3 edge is considerably less than 90 degrees, and the following 2/3 is dead on. I checked the blade runout, looks fine. Then I remembered I always used a blade stabilizer on the thin kerf blades (so I never saw the problem). I added a stabilizer to the Amana, and the "problem" is 98% solved.
I have aligned the pulleys in the past, so I'm thinking it may be the belts. But can the belts cause so much vibration in a full kerf blade?
Thanks
