Writing on a table
Writing on a table
Writing on a table
Ryan Hartje
I am working on a table for my church. The concept is the doors to Wittenburg Castle with Luther's 95 Theses written on it. I am trying to secure some old planks for the table surface. They are rough and I would like to leave them that way and cover with thick finish. I'm not sure how to add the words and what to finish with. Any thoughts?
Thanks,
Ryan
Re: Writing on a table
Well, Since Ol' Marty nailed his to the door, you'd be within your rights to print them on parchment and then decoupage them to the table under a coat of System Three Mirror Coat bar top resin. You might even dog-ear or fray the page(s) a bit. Variation would be to use printable clear acrylic film instead of parchment, apply a first layer of resin, then embed the sheets with another layer of resin. The acrylic with disappear and the words will appear to float above the table's wood surface.
m
Justin Szeliga
I see a number of problems from your description, starting with writing on a rough surface. The rougher the page, the larger the print needs to be to be legible. You'd need to figure how much space you'll have to write, i.e. how many square feet will the table be & how many letters & spaces do you need & can this be written legibly of the rough surface. You may be able to burn the lettering in, or make up stencils & spray stain. A calligraphy pen or brush may do a good job if you know how to handle one.
steve mackay
I've put water-poly over Marks-A-Lot and Sharpie with no bleeding or smearing. The poly has never "picked it up". It will pick up ink (as in ball point or bottled ink) and smear. I HAVE finnished over printed material and done OK. Don't know the properties of the ink though.
AZ in Colorado Springs
Ink from an ink jet printer will bleed when water-based poly is applied over it. Laser printing is OK.
I made a "record album" for a friend to hang on the wall in his party room, scaled to 150%, and put a circular label in the center. I printed the label on an ink jet printer. The brushing of water based poly softened the ink, but I used long strokes in two directions and it bled just a bit and has an "old" or "aged" look to it. It turned out OK and might be appropriate for this rustic piece.
BrianA
Write it out and wood burn it over.
Brian
