REAL MILK PAINT
Another car question, thermostat
Still working on the Honda CRV. Front end fender bender. Replaced the radiator and thermostat and the housing the stat was in. (came as a unit) Put in fresh antifreeze and started the car with the heater on full blast as suggested by the antifreeze container. Let it run for about 20 minutes until the heat gauge went up to hot. No heat came out of the heater. Come to think of it the electric cooling fan did not come on either. What to do now?
Re: Another car question, thermostat
Moses Yoder
Moses Yoder
My suggestion would be to take it to the local mechanic :b Sounds like maybe water isn't circulating through the heater core for some reason.
Jason Roehl in Lafayette, IN
You probably still have a large air pocket trapped in your heater core.
Take off the radiator cap and start the engine. You should see the coolant in the radiator. If not, add it until it's just below the overflow tube. You should also see some bubbles in the coolant, probably large at first, then getting smaller.
Next, from under the hood, hold the engine speed up (assuming there's a cable to the throttle body...you may have to have an assistant press the accelerator so that you can see how to throttle it up from under the hood). The coolant level should drop quite a bit when you rev the engine, and probably overflow when you let the speed drop. If it doesn't overflow when the engine speed drops, you still don't have enough coolant in the system. While holding the speed up, top off the radiator, then put the cap back on. You may have to repeat this process several times to get the air out.
The key is that you need to get the engine speed up to spin the water pump fast enough to push the coolant through the system and force the air out. I've even heard of pulling the "cold" side hose from the heater core to let air escape, but what I described above has always worked for me.
Jason
Fluid level not linked to engine speed
Lee Schierer McKean, PA
Automotive coolant is non-compressible and there is nothing in the system that changes size based on engine speed. The coolant level my drop when you rev the engine because the increased rate of flow pushes out an air bubble in the system into the radiator, but at no time should the level increase when the engine slows. The fluid will expand as it gets hot and should flow down the overflow tube to the overflow bottle. New car radiators should be filled to the top and the overflow bottle should be filled to the cold level mark on the side of the bottle.
Because the heater core may be a high point in the system, it may take some time for all the air to get worked out of the heater core. Always keep the over flow bottle filled at least to the cold level mark.
Lee
We have Success...Thank you, Lots of
Gurgling and belching and maybe a little farting, but it worked. I "knew" It had air in it because I was only able to install about half the antifreeze, just did not know how to get it out. I figured If I limped up to the shop with it it would gurgle the air out and make me look like a helpless idiot.
Thanks again, That's exactly what I needed to know.
All true, but...
...it's what always has happened to me when I've messed with coolant in my vehicles. I suppose it is some sort of slosh effect when the engine speed drops, there's a sudden rush of coolant into the radiator, some of which will spill out, even if the system isn't totally full yet.
Jason
Alexandre Grigoriev
Honda 4-cylinder may have a bleeder screw on the rear side of the block. You need to let the air out with that screw.
