Ash drying
Ash drying
Ash drying
Wooden Dummy
Can anyone recommend how long should I let an ash log (7ft long by 10 inches diameter) dry before I start work with it?
I plan to make a Muk Yan Jong. So I will be making four square bores through the full diameter.
Also, does anyone know if "Mountain" locust is Black or Honey or something separate?
Thanks
Re: Ash drying
Re: Ash drying
John M in Mid Mich
Haven't tried a whole Ash log before, but have done planks and timbers. I think you will have a hard time avoiding some splits if dried in the round. Probably want to seal the ends. Couple coats of leftover latex paint has worked well for me. Then dry outdoors for a year(?) in the shade under cover, maybe a carport. Ash is highly susceptible to powder post beetles and maybe other bugs, so remove the bark and spray the log well with a borate-based product such as Timbor(tm). In fact, if like most of the Ash being harvested these days, it is probably already dead from Emerald Ash Borer followed by secondary infestation by other bugs but these mostly just in the cambium and not yet much in the sapwood.
Bit of a "dummy" myself, so Wikipedia to the rescue on that "muk yan jong":
Re: Ash drying
Clint Searl
Why wait?
Clint Searl
It will split regardless of how long it's left to dry. Strip it and cut the holes now. The sooner you start using it, the sooner you'll become a devestating machime.
Clint
Re: Ash drying
Agree, don't wait
Grant in Iowa
For the log to actually season, it will take roughly a year per inch of thickness (per the generally accepted rule of thumb). It will almost certainly split as the wood on the outside dries faster and more than that inside the log.
There is no reason that the split or shrinkage will ruin the finished product, in my opinion. Pretty much all timbers larger than 4" in thickness will check or split.
I think the key is to expect some splitting and prepare for it. If the plitting occurs in a bad place and appears to be likely to reduce the projects usefulness, you can bore and insert dowels across the splits to allow it to keep its structure.
So I say move on with the project with the green log. Just be aware that green wood likes to cause rust on iron tools, so clean and oil or wax them as you complete each cut/ hole.
FWIW,
Grant in Iowa
Re: Ash drying
let's kill and bury the 1" per year fallacy
Bill Tindall
How fast "lumber dries" depends on species, temperature, humidity, air circulation, target moisture content and geometrical factors of size, shape, thickness,etc. Considering the interplay of all these factors I am at a loss for how this worthless "guideline" could originate.
It deserves to be never repeated and eventually forgotten so as to not risk someone thinking it applies to their lumber drying needs.
Re: Ash drying
Re: Ash drying
Wooden Dummy
Thanks for the input! I will get started right away - I really did not want to wait anyway!
