Have a question? Ask Woody!
Touch latch/push latch feedback sought (long)
HapaJeff
HapaJeff
I will be installing touch/push latches throughout a client�s house to keep their cabinet doors closed in the event of an earthquake. The goal is to find a latch that doesn�t require a key, the turning of a knob, is easy to operate, doesn�t look gaudy, and physically keeps the doors closed.
Currently, they use the Rev-a-Shelf Rev-a-Lock magnetic child safety lock, which uses a magnet housed in a separate �key� to open a lock that is completely hidden behind the door. Keeping the key on hand and having to move it from door to door has become tedious. The locks work well, though.
I am looking for some feedback on some different options that I�m proposing. In particular, I�d like to know if anyone has some long-term feedback on the following types of latches (IE: do you have first-hand knowledge of the longevity/durability of these latches?):
Hafele non-magnetic touch latch, item # 245.50.301 (or similar from another manufacturer), see the picture of the black catch below. My client�s concern with this latch is that it�s made of plastic and may fatigue in time.
Hafele 245.56.901 or similar, see the second image below showing a three-part latch. I�ve heard that these often fail when used daily, but I don�t have first-hand knowledge of such failures.
Ives 820 or CL11 or CL12. I�ve been told that these are very reliable. I do have a sample, and its only apparent drawback is that the latch is a little stiff, but I suspect it will loosen up in time; however, this initial stiffness may be too much for my client.
It bears mentioning that all of the doors in the house have self-closing European cup hinges on them. Some of the doors will be used several times a day, so the latches need to be able to sustain some wear. Also, the doors do have handles on them, so the spring in the latch doesn�t necessarily need to shoot the door open.
Thanks for your feedback.
-Jeff
Re: Touch latch/push latch feedback sought (long)
Your mission is fraught with problems
Keith Newton----Little Rock, Arkansas
First, touch latches work best with free swing hinges. I hope the kick out pressure is greater than the closing power of the hinges.
When there are pulls on these kinds of latches, most people are going to grab the handle and pull. When it fails to open they pull harder and harder.
It doesn't take much misalignment to cause TL's to quit working.
My favorite way of mounting them is to use little pieces of two sided carpet tape.
If you mount the latch first, place a little under the keeper, then close the door on it. Open the door, and stab the holes with an awl, then screw.
Or mount the keeper first on double doors, then reach around and stick the latch to the carcass as it closes while on the keeper.
I have only used the mini-touch latch from Haefele, which is different from all that you show.
Make sure that all the door margins are perfect before mounting these. Threaten any children, or instill horror in them if they climb on the doors. ha,
HapaJeff
Re: Your mission is fraught with problems
HapaJeff
Yeah, I'm aware of the problems.
I'm looking for input on the latches that I've described, not latches in general.
Thanks though.
Good question, Jeff
I've used quite a few touch latches, including #2 and #3 of your examples above. The #2 latch is a positively ancient design and has the disadvantages of being large and tinny and making a lot of noise (the spring is the culprit) and not holding very well.
I recall #3 latch being a little fussy to get properly aligned, but I don't recall any call-backs on them. #1 looks like a pretty nifty unit, though, as your customer said, plastic hardware is prone to breakage.
Couple other things: As Keith mentioned, touch latches are not meant to be used with self-closing hinges, so I would plan on replacing all the hinges, too. I would, in any case, mock up a couple test doors so your clients know what to expect from the new latches. If there are existing knobs or pulls on the doors, the instinct is going to be to pull on the knob, not push. If the catches don't have some escapement, you're likely to ruin a lot of them.
Ellis Walentine, Host
Robby Wright in San Marcos, CA
I too am from California and had the fun? of riding out five major quakes. The one thing I would think about is: "What will the latch do when the door starts shaking hard? Will the latch open from the door bouncing on it?"
Two of the quakes I went through were near 7's and there wasn't a closed door in the house when the shaking stopped.
