Spraying lacquer on cedar
Woodie49
Can you spray lacquer on cedar and the cedar still keep it's aroma?
Thanks
Re: Spraying lacquer on cedar
Clint Searl
Clint Searl
No, plus the cedar oil may react with the lacquer; then again, maybe not. I don't think I'd do it. Do a test and see.
Clint
No
Howard Acheson
Lacquer will completely mask the natural aroma of cedar if you coat all interior surfaces. There is no finish that will work in your desired application.
Second, cedar will not cause any problem with lacquer. Oil based finishes are another story however.
Re: No
FredD
Lacquer on Aromatic Red cedar absolutely will cause a problem beside sealing in the aroma.
I am sitting about four feet from a book case I made for it and the finish crazed and cracked in about a year.
I made some jewelry boxes from it and the same thing happened .The outgassing of the Cedar oil does the damage.
If the object will sit in sunlight the damage happens faster and worse.
The only time I got away with a undamaged Lacquer finish on Cedar, was on a Cedar veneered plywood back I put in our clothes hamper, so one will deduce that was because of the thin veneer not producing enough outgassing to wreck the finish, but you can't smell it in the hamper either, which I already knew would the case, the Cedar was for appearance only and still looks freshly done after 15 years.
FredD
depends
Bill Tindall
If the cedar has been KD at a typical sufficiently high temperature the resin will "set" (meaning volatiles are gone) and you can finish with anything you choose. But the smell will be vastly lessened.
