Scored this load of Poplar
They are widening the road near my house and I saw a pile of logs. Been needing some white wood to use for drawers and internal parts and utility stuff. Had it sawn and the the guy delivered it today, in the rain and snow. Now I have to figure out what to do with it. Too bad I don't have a fork lift. Its about 2250 feet.
Re: Scored this load of Poplar
Moses Yoder
Moses Yoder
Barry, I would store it outside so it doesn't dry out too fast, and put some scrap metal roofing over the top layer. I love getting fresh milled lumber but it is a lot of work.
Drawer parts and utility stuff?
>You won't make enough drawers in your lifetime to need all that poplar. Nice haul though. Good luck with the material handling.
not if he makes much stuff
Bill Tindall
I buy about 300 bdft of #2 common poplar every now and then for secondary wood in furniture. Considering the cutting losses in this grade, just a few projects use it up. For example, in the bow front I am building (approx. 3' x 2' x 5') I have used over 100 bd ft of #2 common poplar for the drawers (the bow fronts alone used up 50 bdft), back and framing.
The lumber can be turned into house parts as needed and that application can use up hundreds of bdf in short order. There is well over 1000 bdft of poplar scattered about our house in the form of trim, shelving, doors, cabinets etc. I find that #2 common makes great shelving and a great alternative to plywood. I don't mind knots in closet shelves.
Were it mine, I would sort it by grade, burying the best lumber in the stack to keep weight on it and putting the low grade on the top. Once it was well air dried, something that will come to pass next summer,early summer if you have good air circulation, I would pull out a few hundred bdft of mixed grades and get it somewhere where it will get dry enough to use- kiln, loft, what ever. The rest can stay in the stack outside for decades if it is covered and sprayed to keep the buggies out of it. Never dead pack lumber out doors, even after it is air dried.
I presume it is 16' long? You will come to hate handling lumber this long but long lumber yields less waste. I certainly wouldn't advocate shortening it. You are going to need a mountain of piling sticks. See if the mill has some well air dried stuff you can cut them out of. They need to be precisely the same thickness or the pile can get out of whack. Just a 1/32" compounded over 20 layers is nearly an inch.
Do treat for bugs *LINK*
John M in Mid Mich
"sprayed to keep the buggies out of it"
Double yes on that. I've been very successful over the last few years with susceptible woods (Ash, Elm, Cherry) with the VERY safe borate based products, e.g. Timbor.
Random Timbor Vendor
Re: Do treat for bugs
Any Idea how much Timbor I need?
Re: not if he makes much stuff
The top layer is actually just over 17' lnog. The shorter stuff is 7 and 8'
Most of it is 4/4 but some is 5/4 and a little is thicker still. Got a few four by fours.
Were you lucky?
Gary Smyth
"Saw ....logs". You may have scored (and been fortunate) more than you know. Around here the contractor owns the logs taken in a right of way. Even the property owner is out of luck. That's part of the deal in the bid. I lost nine trees three generations old of a hardwood view/wind screen to a sewer line, but they would only replace landscape shrubs and turf, but specifically, not the trees in the right of way. The contractor (or a sub) cuts and trims them to length and picks them up after they get a proper load for the mill. Sometimes they are stacked and occasionally left on the side of the right of way. To add insult to injury, "my" trees laid in full sight for three months. In Western PA a lot of Ash, Locust, Walnut, and Oak has furnished the houses, fences, and barns of some of the larger contractors in the area.
Re: Were you lucky?
I bought them from the contractor. I thought I was getting a tremendous deal until he explained that he quoted me a price per hundred BF not Thousand. I never heard of anyone quoting lumber by the hundred. In the end, between the cost of the logs and the sawing, I have about $.50 per foot in it. Does that seem like a deal? I'm trying to convince myself.
John M in Mid Mich
Here is from the label:"Preparation of Treatment Solutions 10% TIM-BOR Professional Liquid Solution: To prepare solution, add approximately 80% of the required volume of water to the mixing vessel. While stirring, gradually add 1.0 pound of TIM-BOR Professional for each gallon of treating solution required. Add remaining water to the solution and stir until the entire product has dissolved."
I've both painted and sprayed it. I think painting is more thorough and economical, but with your pile, I would spray. Best if you spray every board as you restack the pile. Probably want a complete coverage for best effect. I set the sprayer for quite a coarse (large droplets) spray. Looks to me like 5 gallons would more than do it, but I'm only guessing based on what the pile looks like.
depends entirely on the grade and what was measure
Bill Tindall
The detail on the pile is hard to see but it doesn't appear that the logs were large diameter. Small logs will saw up to 30% more than the log measures. Of course small logs don't saw a high fraction of the best grade of lumber. If what you got grades out "average" you did ok presuming you have some need for what appears to be a lot of 4 x 4's and that the price included sawing and delivery. Otherwise it would take very fine poplar logs to bring $500/M.
Buying logs and having them sawed is a good idea if you have need for low grade lumber. It is like buying a cow. If you can use the hamburg it can be good value to buy the whole cow. If you can not use up the #2 common then one is better going to the mill and buying what ever higher grade of lumber one needs. Personally I only buy logs when I have a need to saw something out of them that is not a standard product for the mill, like 12/4 for example. Otherwise I just buy, by grade, the already sawed lumber from a mill. No pig in poke involved in such a transaction as there is in buying logs.
If the 4 x 4's are out of the log centers they will crack severely.
Re: depends entirely on the grade and what was mea
I have not broken the stack down yet, so I have no idea what the pile will grade out. The logs were from about 18" on the small end to about 28". Not the best deal I ever made, but I have what I have.
Bill Tindall
I obviously could not see the ends well in the picture. Those would be considered large to huge logs and if they were clean well worth what you paid for them. They should have yielded exceptionally wide lumber and mostly clear lumber if the logs were good. Have a grand time lifting boards 20" wide by 16' long! ohhh my back.
Think 6 board blanket chests.
I am a little miffed.....
I had these sawed on a band mill and only instructed the guy on thickness. I have looked at the load and am a little miffed that I don't have more wide boards than I do. Most of it looks like about six inch stock. Some is eight or ten inches and the 17 footers appear to be about 12". The sawyer did comment that he thought a lot of it was quarter sawn. I guess I need to go out there and cast a really critical eye on it, but the weather is nasty and trying to stare it into submission won't help. SOMEBODY is going to have to unload that trailer (ME) and I suspect I will get a better look at it then. Even that won't change the contents, just let me know what it is. Whatever it is, I have plenty of it. I did not notice any 4X4's with the pith in them. I suspect if you had glanced at the load, you would have more info than I do. OTOH, when I glance at a house, I get more info than most people. I told the sawyer I wanted some 16/4s stuff perhaps for table legs. I expected planks, not 4x4's. It took me a while to realize he used the 4x4's as dunnage. He did not seem to be in any hurry to get his trailer back. The load is stickered. I may cover the top and let it sit on the trailer a while. Perhaps it will lose a pound or two.
few things in life smell better than a light breez
Bill Tindall
....breeze blowing through a pile of fresh sawed poplar.
I am amazed.....
You must have better soil than we do around here. I was thinking that it stinks. Smells like poplar, but Channel No. 5 it ain't. You would never mistake it for a steak on the grill either.
Lee Grindinger
Birch was my favorite
Lee Grindinger
I dried all the major Eastern species and a bunch of the lesser known ones when I ran two kilns in New York and it was birch that blew my skirt up, it smelled of sweet mint, like a wintergreen mint. I even tasted the water from the dehumidification coils thinking it would taste as sweet as the lumber smelled. Nope, the tannic acid was incredibly bitter.
Gotta ask...
John M in Mid Mich
So, you say "poplar". Is it "yellow poplar", which in botanical terms is not really a poplar, but rather "Liriodendron tulipifera", or "tulip poplar", or "tulip tree"? Tulip tree because of the [extraordinary] tulip-like flowers. That would be a different score than if it is actually a true poplar - botanical name "Populus". And within Populus, in my area (mid Michigan) there are several species, including P. tremuloides (quaking aspen); P. deltoides (Eastern cottonwood); P. grandidentata (bigtooth aspen/cottonwood) and maybe more. The Populus species I believe to be less desirable than the Liriodendron, but I have no personal woodworking experience except with the Lirio. Now, here is a hint: I've heard that the true poplars smell pretty bad in new lumber...
Dale Lenz
Re: Gotta ask...
Dale Lenz
Me think, John's wood is YP. Most of my shop is paneled with Eastern cottonwood, had an odor, nut nothing I couldn't live with. I guess to each there own.
Re: Gotta ask...
John M in Mid Mich
Dale:
I'd love to see a picture of your paneling. I have some gigantic eastern cottonwoods that could become sawlogs of substance, but have no confidence in the utitility thereof. My tree/wood books also suggest that [true] poplar can be useful construction lumber...
John
Now that I think about it....
I don't actually know. The trees were cut and in a pile before I saw them. I think they are the tulip poplar version, but I don't really know. and It could be a mix. I actually stopped because there was a huge oak log laying out near the road and I looked at it to buy it, but it turned out to be mostly rotten. they had cut out what they thought were the saw logs and put them in a pile. they thought I was nuts when I looked at some of the crotches and stuff they had thrown into trash pile to be ground up. I settled for the part that both of us thought was "poplar".
I look at the log piles as I ride by road projects. I scored some Bradford Pear turning blanks and a car load of cherry burls, some as large as basketballs a few years ago.
have to agree
Bill Tindall
But sadly there is little birch sawed/dried now days. The old growth birch that sprouted after the great fires of the 1800's have all been cut from the huge Adirondack estates (Whitney, Litchfield, etc) and other private lands.
I still like the smell of fresh poplar sap wood as a close second (the heartwood is musty).
