flag case dimensions
John Cotten
I have built numerous military flag cases over the years, but I have lost my note book that had the dimensions for them, and not having built one for over three years, I simply don't remember the sizes other than my cases measure 4-3/8" wide. Dale Lenz are you out there? If someone has the dimensions I would appreciate it. I have orders for 5 right now to build.
Thanks
John Cotten
Re: flag case dimensions
Dale Lenz
I be here, John,
Dale Lenz
my cases are 3" deep, from the inside of glass to inside of back panel, like the flag to show in tight quarters. Have a drawing my my router table/ts. But in short, the inside dimension for the bottom is 22", if you cut 22.5* angles and the top 45* the sides are self-measured.
Folded Veteran's American flag are closer to 24" at the bottom, once again I like a glove fit. Cloth will conform to it's container, somewhat.
Hope this helps
Thanks Dale, problem solved.
John Cotten
I really appreciate the help. I have 5 flag display cases and 17 shovel display cases to build between the end of this week and next wed. No problem.
Re: I be here, John,
Bob in NE Ohio
Dale
I have 4 to make in the next weekand have never done one before. I am good with the measurements but what joinery method do you use fo the miters?
Bob
AZ in Colorado Springs
I've made a few flag boxes. For the miters, I just glue them with wood glue. While the TS is adjusted for the mitred angles, I lowered the blade and made gluing blocks to fit over the corners. How to describe it?
Use two pieces of scrap at the left and right ends with a 45 degree cavity cut into them -- make two passes over the TS while the blade is adjusted to 22.5 degrees. Make one pass with each block, then turn the blocks end for end and slide the fence over just a bit and make a second pass with each block. Set the blade high enough that the end of the flag case will not bottom out in the block. The more-or-less square top of the TS blade will not make a clean bottom in this cavity. The sides of the cavity are the important part.
Make a 90 degree cavity in a third block of scrap in a similar way, while the TS blade is angled 45 degrees. This will have a square bottom, depending on profile of the TS blade. Clean the corner with a chisel if necessary.
For the glue up, apply glue to each end of the three boards, then slip the blocks over the ends. One long clamp across the bottom (centered on the width of the boards, and one shorter clamp pulling the top straight down to the bottom. The short clamp pulls the top miter tight, and spreads the two short sides into the other clamping blocks, tightening up the corners.
My gluing blocks for the right and left sides -- the outer sides are not parallel when set in place, but by being careful with clamp placement (I use squeeze clamps with soft pads) they pull together and stay in place. (The gluing block for the top joint -- the top side is parallel to the bottom of the flag box.)
John Brown
John,
Go to google and put in: Building a flag case, this will bring up several good sites on this subject.
Jack Brown
Dale Lenz
Sorry, I missed your post, Bob... *LINK*
Dale Lenz
I'm still not back to normal after my gallbladder surgery, I'm the 4% that did not fair well, I guess.
I'm not sure of your question, IIRC, you ask what jointery method I use to make my miters. Well in the last few years I've been using a 12 DeWalt miter saw with a Forrest blade, then sweeten the joint up with a hand plane. My bottom joints are 22.5* on all four corners. Top joint closes at 90 or 2) 45*. If you like visit my website, will post below. Feel free to contact me by email and I've give you my phone number and we can discuss the flag case over the phone.
Went to my day job today for 1/2 day, will try again tomorrow. So I might be difficult to catch.
Flag Cases
