OT Groutable Vinyl Tile
Tom Rex
I am remodeling a bathroom that is approximately 4� X 6�.
Home Depot has vinyl tile that is groutable and looks like ceramic tile.
I am looking for opinions on the pros & cons of using this tile.
Thanks for your response,
T Rex
Re: OT Groutable Vinyl Tile
Randy
I have been looking at the same tiles as well, looks good but have not seen anyone actually use it.
Mark Nowicki
We use it in our rentals, about 3000 sq.ft. up to now.
We and the tenants love them.
They look good, they are durable, and feel "rich" underfoot. In three years we have not had a single rip or glue failure.
We have never had the opportunity to grout them.
We always rip off as much of the old flooring as is practical, put down new sub-flooring (usually 3/8 select plywood), apply sealer AND ROLL.
Mark
Randy
No problem if not grouted right away?
FredD
Are you using the 3/8th ply for subflooring , or did you mean underlayment?
If that is the case your spending way to much for underlayment.
If it is used for subflooring , it is way to thin.
Just a thought , mind you
FredD
Mark Nowicki
Mea culpa, I meant underlayment.
We tried 1/4 and decided to change to 3/8. It bridges the defects better.
Mark
Tile
Mark Nowicki
I think it would be a problem.
Mark
My niece has it
Ray - Middletown, IN
She installed it about 4 months ago and with 4 kids rough housing around it seems to be holding up fine so far.
Ray
Justin Szeliga
Lemme see, use a method & products that would be familiar to a mechanic from 2000 years ago, or the new, plastic stuff they are selling at HD.
I would say that a 4x6 bath is a nice area to learn tilework on. Lots of online info, try John Bridge forum, Tile Your World, for starters.
Using 1/2" cement board, modified thinset & a $100.00 wet saw & you can do a great job & have a very water resistant floor probably for a competitive price. & if the vinyl is a lot cheaper, I'd say there is no way it'll last as long as ceramic.
I work doing remodeling & have seen & removed the fads of the last 75 years in home construction, this sounds like another one.
I have never seen vinyl tile that you grout. Am I understanding this. Is it really vinyl and you grout it with tile grout???
I have recently done several floors with real ceramic tile. Bought a tile saw for slightly less than a hundred bucks. Worked for me. Pretty straight forward. Not nearly as intimidating as it seemed. It turned out we had a room that was about 4x6' and it was actually cheaper to use tile that vinyl.
Bill Blasic
Bill Blasic
My sister is having this tile put down, when I was there yesterday it was almost finished. The grout to be used is a slow set epoxy. She has dogs and dogs have accidents and the epoxy grout keeps the accident from getting underneath the tile. 18 hours till you can walk on it and 3 or 4 days till totally cured. I noticed that they used spacers just like you do with the real stuff.
Bill
